titanium aftermarket spindles for dura ace pedals
spartan
by spartan
has anyone tried this retrofit? any info on the manufacturer.
https://titaniumplanet.com/index.php?id ... rsion-9100
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
tommasini
by tommasini
If I recall correctly, the 9100's use loose balls up near the crank threads - and these loose balls run directly on the original steel spindle. So by putting in a Ti spindle you will be running those bearings directly on a Ti surface. My thought is you will quickly wear a groove on the spindle as the Ti will wear much faster than with the hardened steel
