Lightweight full length mudgaurds for gravelbike with 40mm tyres
frogtape777
by frogtape777
Morning Guys,
Any reccomendations?
by Nefarious86
SKS Blumels? Image
Using Tapatalk
frogtape777
by frogtape777
Thanks, any similar which have the flaps front and back?
fasdflkjweorinjs
by fasdflkjweorinjs
I bought some 63mm velo orange fenders for my 47mm 650b wheels + tires and I love the combination. They were also very easy to mount. Unfortunately they are heavier than plastic fenders but I feel the weight is worth the tradeoff for the best protection against wheel splash. It wasn't until I put this combination together that I could go out riding in torrential rain (I live in Vancouver, CA) and get home with dry feet.
spdntrxi
by spdntrxi
If you have room for Portland Design Works 650Beast fenders... that's where it's at.
Marin
by Marin
Velo Orange
Diy flap that almost touches the ground
Dennisbley
by Dennisbley
Not sure if these will be large enough, but this is what I have on my bike w. 650b x 42. Certainly light as hell
https://www.veloduo.co.uk/collections/m ... 35-40-50mm
Dennisbley
by Dennisbley
Dennisbley wrote:
Mon Mar 11, 2019 5:56 am
If you pursue this route, let me know, I have a coupon code I wont be using
Dennis
TonyM
by TonyM
Dennis
How much would be the discount?
Dennisbley
by Dennisbley
TonyM wrote:
Mon Mar 11, 2019 7:14 am
Dennis
10%
Catagory6
by Catagory6
does your frame have eyelets for mounting fenders?
if not, Planet Bike make a full fender with flaps that strap on to the seat stays and fork blades
they're kind of finicky though. and if your seat stays are dropped in any way other than connecting to a horizontal TT, it will be hard for the bracers to reach. i had to make a shim
jeanjacques
by jeanjacques
40mm Curana Clite with alloy stay, hardware and front DIY extension, 270g.
Miles253
by Miles253
I’ve got the Blumels and they’re pretty damn good, I’m sure there are additional flaps you can buy...
Specialized S-Works Venge Disc | 7.8kg
Rose Backroad | 9kg (Deceased R.I.P.)
Canyon Ultimate CF SL | 7.7kg
https://www.findyourroad.co.uk/
Instagram: @miles_bc
Beancouter
by Beancouter
Was planning to get the Veloduo for my ibis. Planning to run 35mm gravelking (not sk) on 29mm wide lightbicycle rims - does anyone have a view on whether I might get away with a 40mm 700c guard (it says 32mm max tyre) or whether a 45mm for a 650b wheel would work better (36mm 650b tyre max)?
Cheers
sqber
by sqber
Velo Orange Hammered Fenders, 45mm. Available in black and silver.
Looking at this photo, I wouldn't go to a group ride with this setup as the guy riding behind you gets soaked. The rear fender is so short, it should end about 20 cm above the ground to be any good the riders behind you
