High performance tubeless with tan side walls?
parajba
by parajba
As per title, I had a look but cannot find any high performance tubeless with tan sidewalls.
I am after a size 25mm (or 28mm for the rear perhaps).
The reason I need them is because I think they look pretty nice with a black bike (e.g. need Venge).
By high performance I mean something comparable to the Corsa, 5000, etc.
kulivontot
by kulivontot
Pretty sure Vittoria corsa speed TLR comes in a model with tan sidewalls
TobinHatesYou
by TobinHatesYou
kulivontot wrote:
Sat Dec 22, 2018 5:45 pm
Pretty sure they only come in gray (labeled anthracite) and black.
parajba
by parajba
Thanks but the Speed are the super light version. I am after a high performance tubeless tyre but not too light, something like the normal Corsa, the TurboCotton, the 5000s etc.
Quite surprising I can’t find any with a tan side wall. Was planning to go tubeless on a future SL6/Venge purchase and quite like the tan look...
TobinHatesYou
by TobinHatesYou
The problem is that “natural” sidewalls are porous, so they need to be coated with rubber anyway. The Corsa Speed TLR were originally going to be available in tan, but they couldn’t solve the weeping problem without adding about 20g worth of rubber to the sidewalls,
Compass tires (Panaracer) have some TLR gravel tires with natural color casings, but they have been known to weep sealant...and also the TLR versions are only on some of the wider tires.
kulivontot
by kulivontot
Yesh thats right. I was thinking of the G+ tubulars, which only came in tan at the time.
parajba
by parajba
Sat Dec 22, 2018 8:43 pm
I see, thanks for the explanation, that’s why I can’t find any tan tubeless...Pity as I quite like the look on a black bike.
TobinHatesYou
by TobinHatesYou
You can find some, but they are typically just dyed rubber. There are “tan” Schwalbe Ones and some Panaracer GKs with brown sidewalls.
arthurf
by arthurf
Corsa G+ will be available in a tubeless version in the new year in both tan wall and grey wall
parajba
by parajba
arthurf wrote:
Sun Dec 23, 2018 9:44 pm
Really?!? Awesome. How reliable is your source? The Corsa G+ (clincher) is my current favourite tyre, if they made a tubeless version (and if they made it with tan side walls as optional) it would be fantastic.
Do you have an ETA?
jlok
by jlok
Back then in September, Vittoria replied to my request for 28c tubeless Corsa. I hope I could use it on my 4.5 AR.
Hi,
Thank you for your email. We will have a 28-622 (700x28c) Corsa TLR in all black in 2019.
Unfortunately we will not have this size in gum color sidewall.
Please let us know if you have any other questions. Thank you.
Best regards,
Customer Service Team
Vittoria Asia Pacific Limited
dim
by dim
Trek Emonda SL6
Miyata One Thousand
mattyNor
by mattyNor
They're somewhat impossible to find but tan wall tubeless Pro Ones exist
Sent from my Pixel 2 using Tapatalk
dim
by dim
not tubeless but get Specialized Turbo Cotton and use latex tubes .... amazing tyres .... and fast! .... (I've had them several occasions, and I will buy them again)
Trek Emonda SL6
Miyata One Thousand
Marin
by Marin
Yea but not tubeless, completely different thing.
Running clinchers in Roubaix is probably the worst idea since you'll pinch flat all the time. Tubulars may be better, but cobbles are where tubeless really pays off.
