700x45 tyres on 18/23 alu rims?
Champ5000
by Champ5000
Hi all
I currently ride at set of Schwalbe Rapid Rob 700x35mm. on my alu wheelset which have an outer width of 23mm. and inner width of 18mm.
I would like to switch to either 40 or 45mm. - however I don't know whether it is possible to fit this size on the size of rims that I have or not.
Does anyone have experience with this?
Marin
by Marin
I'm running 48mm Gravelking SK (650b) on 19mm internal rims. Running about 1.8 bars. No Problems.
AJS914
by AJS914
I have 40mm tires on a 20mm internal rim. It works fine. I doubt that a couple of mm less of internal width would make a huge difference overall.
onemanpeloton
by onemanpeloton
43mm gravelkings on an 18mm inside diameter rim works fine for me. I've used them down to about 35psi
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
Champ5000
by Champ5000
Great - Thanks for your replies.
I am debating with my self whether I should go for the:
- Panaracer Gravelking SK Tubeless Folding Tire - 622 - black / brown or
- Schwalbe G-One Allround Evolution - LiteSkin - Folding Tire - 40-622 - Classic-Skin
Any thoughts?
Will be used in the dry on a mix of tarmac and forrest trails.
Thanks.
Marin
by Marin
The Gravelking will probably be tougher, the G-One faster.
If you mostly ride in the dry you should consider slicks.
