Stem with a 35mm stack?
Catagory6
by Catagory6
Seems like only stems I can find have 40mm steered tube clamp stack.
Other specs :
6 deg
100-110 mm
31.6
Preferably aluminum
Catagory6
by Catagory6
Or, is there any compression plug that adds on extra 5mm or so of clamping area above the steered tube?
In hesitant to go with 0 degree, or riser stem because they look goofy as fudge.
TheDoctor
by TheDoctor
For what it's worth: Deda makes the aluminium Superzero stems - these have 36mm stack height which could be close enough for your purpose, but they are 8° (doesn't make a huge difference with 100/100mm length) and nominal 31.7mm bar diameter.
Specialized S-Works Tarmac SL6 Disc
Cervelo R5 Disc
Argon 18 Nitrogen
Argon 18 Gallium
Canyon Exceed CF SLX 8.0
Felt Decree 1
wheelsONfire
by wheelsONfire
Deda Superleggera RS
34mm stack (true measure height)
-8 degree
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Catagory6
by Catagory6
lets see if i have my basic math correct.
stem length, and angle being equal, the difference in bar-clamp center would be 2.5mm between a 35mm stack and a 40mm stack (when measured from the base of the steerer tube clamp)?
looks like i'll be ok
shimmeD
by shimmeD
There're a couple of online calculators in this thread https://weightweenies.starbike.com/foru ... 3&t=154459 :welcome:
Less is more.
TheDoctor
by TheDoctor
Mind that going from a 6° stem (your current situation) to an 8° stem (Deda) will also lower your bars by a few mm. Nothing disastrous imo.
Cervelo R5 Disc
Argon 18 Nitrogen
Argon 18 Gallium
Felt Decree 1
