Anybody mounting Vittoria Pave's 25C or 27C
welchy
by welchy
Hi Everybody,
Currently dialling in my bike setup early to ride Paris Roubaix next year.
Wandering if anybody has measurements for Vittoria Pave in 25C or 27C mounted to a C17 internal width rim.
I am putting them on campag Zondas, so far my Conti GP 25Cs measure 26.8 at 100PSI on my rims, but I hear Vittorias are pretty true to size. If so I could get away with fitting a 27C Open Pave on my Nago C60.
Cheers,
Tom
Marin
by Marin
They'll be true to size on 17c I guess.
Good choice, I still think the Open Pave is the best riding clincher period, even compared to Grand Bois / Compass etc.
1415chris
by 1415chris
Pave 25 on 17.5mm internal and 23mm external rim.
bm0p700f
by bm0p700f
They are true to size on 17mm internal width rims.
Yes the pave is the best clincher for grip and ride there has been . I wonder if the new Corsa control is the reincarnation.
Marin
by Marin
bm0p700f wrote:
Mon Dec 03, 2018 11:53 pm
Since the new Corsa G+ rides much worse than the old Open Pave, I'd be surprised if the Control with added protection had a better ride - but I'd love to be proven wrong.
welchy
by welchy
1415chris wrote:
Mon Dec 03, 2018 10:44 pm
Amazing, many thanks for this. If they fit true to size my Conti GPs are measuring 26.8 on my rims at the moment so I am hoping I can get away with buying the Open Pave 27C!
Fingers crossed.
Thannks everybody!
bm0p700f
by bm0p700f
Marin oh that's a shame. Bring back the pave.
Frankie - B
Administrator
by Frankie - B
Most important is, what tubes will you be running? I had the same issue during my first Roubaix, my bike would only accept tires up to 25/27mm. So i ended up getting a set of Challenge Strada 25mm open tubulars and mounted these with Challenge latex tubes. Heard the dreaded 'twoink' of the rim hitting a cobble about 5 times, but never had a flat. I'm pretty sure that a butyl inner tube would have flatted in such a collision with a cobble.
Please follow me on Instagram
Marin
by Marin
Everywhere where you can pinch flat ist a perfect application for tubeless to be honest.
welchy
by welchy
So are we saying latex tubes is going to be the way forward for Roubaix? My only concern here was dropping psi along the way, which wouldn't be the worst I guess. It'll be 5/6hrs so not too bad.
bm0p700f
by bm0p700f
Roubaix is perfect for tubeless. If I go next year I will be using tubeless tyres.
The or cobbles are do rough you won't notice any difference between tubes types. Imho you need a wider tyre. The last time I went I used a 30mm tyre challange Strada Bianca at 55 psi and was passing almost everyone. Wider tyres are better.
Frankie - B
Administrator
by Frankie - B
On my run next year i certainly hope to use the strada bianca 33mm tubeless. I hope to be wafting over the cobbles.
