Will an ultegra small chainring fit and work ok on a duraace crank?
alcatraz
by alcatraz
Hi wws...
Like the description I'd like to know if an ultegra 6800 small chainring will fit on a duraace 9000 crank?
Thanks
/a
ill principe
by ill principe
And on a similar note;
Will a Ultegra 8000 inner/small chainring play nice with a DA9100 outer/big ring?
ms6073
by ms6073
alcatraz wrote:
Mon Dec 03, 2018 12:34 pm
Ultegra 6800 chainrings will interchange with DA 9000 cranks and vice versa, and the same also applies to interchanging 8000 and 9100 series chainrings, but 6800/9000 chainrings will not fit 8000/9100 cranksets.
alcatraz
by alcatraz
Thanks ms6073 :thumbup:
kwakekeham
by kwakekeham
Also the edges on the arms don't line up particularly well when you interchange rings. Not really a problem, unless you're a heel rubber / duck foot rider or aesthetics are important.
