What's the new hot alloy tubeless rim?
kulivontot
by kulivontot
Hey guys,
been out of the Weight Weenie game for a couple years, looking to build up a new set of ultra-light alloy rims. I weigh 60kg, so pretty much every option is on the table for me.
In the past I had a couple sets of Stan's alpha 340's, built up 1150-1250g, depending on the rim generation, but I've tacoe'd like 3 of them now in crashes, and I keep having issues with road tubeless since the bead shelf design does nothing to keep the tire onto rim when it deflates (makes it impossible to seat them with a compressor with the valve core removed since you have to put it back in to re-inflate). I really liked the "Road Tubeless" American Classic wheels since they were hella light, and super easy to set up as tubeless, but of course they don't make them anymore.
My option used to be:
-Stan's 340 - tires explode off rims, expensive, and it seems like modern road tubeless tires don't like these rims
-Pacenti SL23's - rim cracking issues, replaced with Forza
-Amclassic road tubeless/RD2218 - out of business
-Ryde Pulse/Sprint - doesn't seem available anymore
-Kinlin XR22/26/31T - still available
It seems like it's really hard to find a sub 400g rim these days. What are the new options?
nachetetm
by nachetetm
Mavic Open Pro UST. Although they are suppoed to weight 435 gr per rim, most of the people are weighting them under 410 gr. They seem to work very well tubeless too.
C36
by C36
+1 for the new Open Pro
ooo
by ooo
Rim brake or disc brake?
Pulse Sprint available from r2-bike
kulivontot
by kulivontot
I can't believe that in 2018 the best alloy rim is a Mavic open pro. What happened to this industry?
Rim brake preferred. Is it just a function of rims being wider now? Or did companies figure out that you can't build light rims without their customers cracking them?
silvalis
by silvalis
Why is that? They were only announced last year and became available this year...
Chasse patate
Multebear
by Multebear
kulivontot wrote: ↑
Thu Nov 22, 2018 6:43 am
We’re not talking about Open Pro’s, we’re talking about the newer version named Open Pro UST. Completely different animal.
Haven’t tried them, but there are a lot of positive reports online about them. A few negative as well though.
F45
by F45
Mavic makes a good rim when they set their mind to it. It just took them a loooooong time to get over themselves and update it.
Durability remains to be seen....at the prices they want I'm not the guinea pig.
They also threw in the towel on hubs - most of their 2019 mountain wheels have a DT star ratchet type design, with steel spokes!
"It seems like it's really hard to find a sub 400g rim these days. What are the new options?"
The market wants wider rims with the tubeless profile. That costs material. But aluminum material science hasn't improved much so you get offered heavier rims or they get taken off the market for durability reasons (Pacenti, Ryde, Alpha, etc....)
Monkeyfudger
by Monkeyfudger
ÂŁ40? Hardly pricey, most probably spend more a month on coffee.
C36
by C36
F45 wrote: The market wants wider rims with the tubeless profile. That costs material. But aluminum material science hasn't improved much so you get offered heavier rims or they get taken off the market for durability reasons (Pacenti, Ryde, Alpha, etc....)
Aluminium will always have the same « material stiffness » (young modulus) and you are limited in terms of shapes (shape stiffness - the quadratic moment-). Some exotic aluminium (metal matrix type or Aluminium-lithium) are not really compatible with a rim extrusion process...
Then it’s not really that the science hasn’t improved but there are limited options technically possible. The 4D milling Mavic developed is the only real engineering improvement that exist to optimise stiffness-resistance to weight.
MikeD
by MikeD
kulivontot wrote:I can't believe that in 2018 the best alloy rim is a Mavic open pro. What happened to this industry?
I doubt the new Open Pro is very good. The old one wasn't. It also has a drilled rim bed, which is not as good as a rim that doesn't have spoke holes if you are using tubeless.
wheelsONfire
by wheelsONfire
I had Ryde Trace 22. First tire popped off during cornering, then later on it cracked.
I went for DT Swiss and it has been great.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
AJS914
by AJS914
kulivontot wrote: ↑
Wed Nov 21, 2018 8:49 pm
You might consider:
Aforce AL33 - 465g
Hed Belgium / Belgium + 465g
Boyd Altamont / Altamont Lite 485g / 445g
Easton R90SL 455g
Kinlin has various lighter rims.
Maybe the Altamont Lite is the ticket for you?
C36
by C36
AJS914 wrote:
kulivontot wrote: ↑
You might consider:
Aforce AL33 - 465g
Easton R90SL 455g
Are those real or theoretical weights?
Aforce al33 are 500g real, then a lot less interesting
Marin
by Marin
Kinlin XR22 or XR31
