Post your Small budget weight saves
WILLIAMDENYS
by WILLIAMDENYS
wheelsONfire wrote:Exactly!
Still strong enough?
Verzonden vanaf mijn iPhone met Tapatalk
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
themidge
by themidge
dmp wrote:
Wed Nov 21, 2018 7:58 pm
Changing to Ti cleat bolts and washers for Look saved (if I remember correctly) less than 10g. But weight savings wasn't the reason I did it- it was because the Ti fittings don't rust, and cleat bolts are highly subject to rust.
This is a great excuse for doing a little bit of bolt tuning, I like the idea of have a bike that is as non-corrosive as possible (so bolt-tune your winter bikes everyone! :D ).
Places I can think of where bolts are likely to corrode eventually:
- brake bolts/recessed nuts, these are the worst for rusting
- cleat bolts, as mentioned already
- limit screws
- bottle cage bolts if left unattended long enough
- not bolts, but the steel axle of quick release skewers can suffer
Stendhal
by Stendhal
maxxevv wrote:
Tue Nov 20, 2018 7:50 am
Stendhal wrote:
Tue Nov 20, 2018 3:49 am
My suggestion -- and I am surprised no one has mentioned it yet, to my knowledge -- is to fill your tires with helium instead of air. Helium is lighter than air so you'll save some grams. Plus, you may be able to float up the climbs, ahead of your club ride friends. (Why else do you think Ridley named its climbing bike the Helium)? Also, at coffee stops, you can delight your friends by taking a nip from the tire valve and speaking in a squeaky voice.
Except that you can't use helium on normal rubber tubes nor tyres ....
True, unless you line the tire and tubes with mylan. I'm surprised this hasn't happened yet
https://en.wikipedia.org/wiki/Lifting_gas
As the article states, it would not help as much, but you could use neon instead. As a side benefit, your tires will glow in the dark!
Thinking about this further, now we know why Miguel Angel Lopez was not able to keep up with Chris Froome on the mad climbs up the Sestriere on stage 19 of this year's Giro. Lopez rides for the Astana team, on Argon 18 bikes. Obviously they were filling their tires with argon, which is heavier than air.
All in good fun! Seriously, wouldn't it be the height of weight weenism \ First World optimization to develop lighter than air tire systems? Maybe this is occurring in secret, like the secret motors inside wheels "discovered" by the Italian press. Call the UCI -- there could be Air Doping going on!
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
C36
by C36
Helium is not new. If I recall properly Merckx did his hour record with helium in the tubulars.
The molecules are so small that they pass though the rubber and pressure drop is really quick.
Stendhal
by Stendhal
C36 wrote:
Thu Nov 22, 2018 1:02 am
That's so cool! Proof again that Eddy Merckx > us mere mortals.
Lewn777
by Lewn777
I would be very careful about cutting seat posts and using small and light expanders. Likely you'll save 50g-100g between them but it could cost you your frameset.
The stem bolts need to be supported and some manufacturers recommend their OEM expanders only. Using a small lightweight expander could void your warranty and cause undue unintended stress on your steerer. Some manufacturers are okay with small and light expanders but most are not.
Some manufacturers demand that you use at least 10cm or even no more than 10cm inside the frame. Therefore if you cut a shorter seatpost than the OEM one even if you are longer than the marked minimum insert you can void your warranty. Some bikes are well reinforced around the seat post and top of the seat stays and brake bridge but some aren't. If your frameset or bike comes with a stock seat post than isn't a boat anchor I'd just leave it. If it came without one or was heavy find a nice one but measure 10cm inside the frame and ignore the minimum insert mark, any weight saved is a bonus.
mag
by mag
You may seal the frame and fill it with Helium as well ;-)
Anyway, drillium!
WILLIAMDENYS
by WILLIAMDENYS
Lewn777 wrote:I would be very careful about cutting seat posts and using small and light expanders. Likely you'll save 50g-100g between them but it could cost you your frameset.
Does the smaller expander destroy your tube because you tighten your handlebar where there is no pug inside?
pdlpsher1
by pdlpsher1
dmp wrote: Changing to Ti cleat bolts and washers for Look saved (if I remember correctly) less than 10g. But weight savings wasn't the reason I did it- it was because the Ti fittings don't rust, and cleat bolts are highly subject to rust.
+1. I got my Shimano cleat bolts and plates on eBay and shipped from China. Very high quality and they won’t rust.
pdlpsher1
by pdlpsher1
WILLIAMDENYS wrote: Does the smaller expander destroy your tube because you tighten your handlebar where there is no pug inside?
Yes. Most stem clamps are 40mm tall. You need an expanded that’s at least 45mm tall.
WILLIAMDENYS
by WILLIAMDENYS
Oh okay so those tiny ones are bad
Lewn777
by Lewn777
WILLIAMDENYS wrote:
Thu Nov 22, 2018 5:37 pm
Not always. It depends on the manufacturer, but as a general rule, yes. There are some good threads about this, I should dig them out.
dereksmalls
by dereksmalls
Tune cable housing
C36
by C36
dereksmalls wrote:Tune cable housing
Read a bit about them but never seen them. What makes them light and anything special using them?
2lo8
by 2lo8
Stendhal wrote:
Thu Nov 22, 2018 12:52 am
Realistically (as realistic as helium in tires go) you're not trying to get lift force though. Tires are under pressure. Assuming you have a constant pressure, according to the ideal gas law, (assuming ideal) PV=nRT. Assuming V is constant because of tire size, T is constant because it's not going to change based on gas, and R is a constant, that means P is proportional to n. The molar mass of helium is 4g/mol. The molar mass of air is 29g/mol.
For a 700x23 tire, experimentally, each bar/atm of air adds about 1g ( https://2lo8.wordpress.com/2016/06/24/j ... -than-air/ ), which should be directly proportional to the moles of air in the tire, and the mass directly proportional to the moles of air. So assuming that I didn't forget how to do stoichiometry, if you would normally have ~14g of air in your tires, that would be ~2g with helium. That would be about equivalent to 1 bar/atm of air pressure at sea level since that was experimentally determined to be ~1g/bar per tire.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
