What pressures do you run on your Vittoria Corsa G+ tubs?
neeb
by neeb
The minimum pressures seem very high. I'm 64kg and currently have a 23mm tubular on the front and a 25mm on the rear and am running both at 95 psi, but the minumums on the sidewalls are 115 psi for the 23mm and 100 for the 25..
Feels good at the pressures I'm using. Wondering if I might be risking pinch flats (I know from experience that tubulars DO pinch flat sometimes).
Wookski
by Wookski
Vittoria’s recommendations are based on ETRTO and take into account worst case scenario of rider weight, load etc. They’re notoriously high and universally ignored. Depending on conditions I run corsa tubs at 75 to 90 PSI.
bikeboy1tr
by bikeboy1tr
I weigh 81kg and run typically run my Vittorias at 100 psi for 25mm and 110 for 23mm. Long as you cannot feel the tire contacting the rim on impact of the roughest of bumps you encounter than it should all be good.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
neeb
by neeb
Brilliant, thanks both.
Kayrehn
by Kayrehn
Yes I've questioned that myself in the past when I used their app which gave me quite a large number for their recommended pressure. I'm 70kg and I run 25mm at 90/100 max (roads here are good).
Alexandrumarian
by Alexandrumarian
I'm from 92 to 98kg and these days I settled on ~110 rear 100 front (7.5 and 7 bar to be precise) I used to pump the rear to 8 when I first got tubs (25mm Arenberg or G+) then gradually tried less with no ill effects. I also have a 27mm rear wheel and go for 5.8-6 bar depending on road.
Rappid
by Rappid
I just found Corsa G+ in 26mm.
Has anyone tried these?
Jbass
by Jbass
Running 100 psi, 25 mm tubs.
mortirolo
by mortirolo
"23mm tubular on the front and a 25mm on the rear"
75kg
front: 105
rear: 95
Marco Pantani - Momenti Di Gloria
