Raleigh Willard 3 Full Strip Down
prebsy
by prebsy
In the pursuit of truth I will be stripping my new Raleigh willard 3 down to every piece before rebuilding , with some alterations. The Raleigh Willard was an extremely attractive option for what I call gravel, which really a mix of road , gravel and single track. I'll be taking delivery tonight and hope to have everything up in the next day or two.
A big shout out to @Prendrefeu and his always inspiring caad12 strip down thread.
viewtopic.php?f=3&t=137189
FINAL STOCK BUILD WEIGHTS
  • Part--- Description--- Weight
    Frame: Willard 3 56cm + bottle cage bolts + praxis BB- 1880
    Fork: Willard- 737
    Headset: Raleigh- 114
    Stem: HED Eroica 100mm- 143
    Saddle: Raleigh- 290
    Seatpost: HED Eroica 27.2mm- 308
    Handlebar: HED Eroica 42cm flared- 307
    Seatpost binder: Raleigh- 23
    Right Shifter: Sram Apex1- 169
    Left Shifter: Sram Apex1- 127
    RD: Sram Apex1- 313
    Bottom Bracket: Praxis M30 BSA (included in frame weight)-
    Crank: Praxis Alba 172.5 DM 38T- 636
    Chain: KMC X11-1 EPT Anti-Rust- 257
    Cassette: SRAM PG1130, 11 Speed,11-42- 528
    Brake Calipers: TRP Spyre C + Bolts- 347
    Brake Rotors: TRP Spyre + Bolts- 256
    Cables&housing: Jagwire + rear brake foam- 172
    Front Wheel: HED Tomcat- 854
    Rear Wheel: HED Tomcat- 979
    Tires: Clement X'PLOR MSO, 700x40c, 60TPI- 914
    Tubes: Kenda 700X35-43- 316
    TA: Raleigh- 160
    Bar Tape: Raleigh- 84
    9914
Marin
by Marin
Interested.
weinstev
by weinstev
I'll be receiving a Willard 4 in a few days and I believe that the Willard 3 and 4 share wheels and frames, so I'm interested, too. The bike will be a warranty replacement for an aluminum Redline Conquest Pro on which the right seatstay snapped off where it was welded to the bottom bracket. From what I've read online, I should expect the bike to weigh about 10.5kg out of the box with HED Tomcat rims, 40mm X'Plor MSO tires, Shimano 105, and TRP Spyres. Your efforts will be appreciated...
prebsy
by prebsy
Tapatalk limits to 9 pics at a time so here is the first batch
Frame with praxis bb 1869
Headset 114
Fork 737
Hed erocia stem 143
Sram 1130 cassette 528
Brake housing liner and plug 4
Apex1 Rd 313
Apex right shifter 169
Apex1 left brake lever 127ImageImageImageImageImageImageImageImageImage
Sent from my Pixel XL using Tapatalk
prebsy
by prebsy
Round 2
Brake cables 32
Shift cable 13
Brake housing 91
Bar tape 64
Praxis Alba left arm 227
Praxis Alba right arm 313
Praxis 38t dm with screws 96
Trp spyre rotors and bolts 256
4 bolt cage bolts 11ImageImageImageImageImageImageImageImageImage
prebsy
by prebsy
Round 3
Housing doodads 3
Raleigh TA's 160
Shift housing 29
Kmc chain 256
Tubes 316
Raleigh saddle 290
Trp spyre c with bolts 347
Seat post binder 23
He'd erocia seatpost 308ImageImageImageImageImageImageImageImageImage
prebsy
by prebsy
Round 4
Hed eroica flared bar 307
Hed tomcat front wheel w tubeless tape 854
Hed tomcat rear wheel w tubeless tape 979
Bar ends 20
Clement mso 40mm wire bead 463&451
prebsy
by prebsy
Haven't even had time to get totals already rebuilt with my wheels and cockpit. Will get a final weight when I get the tubeless setup to work.Image
