s works sl5 bottom bracket
WILLIAMDENYS
by WILLIAMDENYS
having an sl5 with stock bb30 bracket in there . im using a ultegra 8000 crank so i have spacers in between there. never replaced a s works bracket so dont know how it works.
i would like to have a bb that already has that spacing on there. can i just bust the bearings out and put something like this c bear in? https://www.c-bear.com/nl/products/bott ... face-rotor
or do i need to remove the epoxied cup?
someone that done something like that before?
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
ParisCarbon
by ParisCarbon
If you have a stock Tarmac SL5, its just a BB30 bearing in there with an outboard reducer cup to allow the shimano spindle... its just a matter of knocking out the bearings and installing what you want.. I did the ceramic speed 2 piece bb30 for shimano in mine, just screws togther. Ive since changed to Campagnolo, so just unscrewed the whole thing out and put it in my TT bike...
I think its this one you need:
In my 2016 Tarmac I used this one:
https://www.ceramicspeed.com/en/sport/s ... mano-road/
I was using a Dura Ace SRM in mine, but don't think the Ultegra is any different for setup? But I could be wrong..
WILLIAMDENYS
by WILLIAMDENYS
and you just screwed that ceramicspeed in?
WILLIAMDENYS
by WILLIAMDENYS
ParisCarbon wrote:
Wed Oct 31, 2018 11:10 pm
just screwed it in? (ceramicspeed bb30 shimano?)
ParisCarbon
by ParisCarbon
Its a 2 piece design, the 2 pieces thread together and join in the middle.. you will need 2 BB tools that match the spline design on the cups.. push em in, thread em together... never creaked once!
WILLIAMDENYS wrote:
Thu Nov 01, 2018 7:06 pm
WILLIAMDENYS
by WILLIAMDENYS
ParisCarbon wrote:
Thu Nov 01, 2018 7:17 pm
and does it spin like crazy? i have the stock ceramic now and doesnt very impress me.
ParisCarbon
by ParisCarbon
Spun like crazy for me... what year is your frame.. you mentioned "epoxied cups" If its 2015 or later, my understanding is you don't have those OSBB inserts, and its a straight up BB30... post a pic of it if you can.. Id hate to lead you down the wrong road at the price these BBs are... I have the Tarmac SL5 Sagan Camo and its a BB30... the Sl6 and Venge use the exact same thing...
WILLIAMDENYS
by WILLIAMDENYS
ParisCarbon wrote:
Fri Nov 02, 2018 12:00 am
this is how i bought it. now with spacers and crank
ParisCarbon
by ParisCarbon
Looks like mine.. pretty sure all SL5s are BB30..
WILLIAMDENYS
by WILLIAMDENYS
ParisCarbon wrote:
Fri Nov 02, 2018 11:18 pm
i'll buy a bb30 shimano ceramicspeed. hope mine will spin good af.
mushroom
by mushroom
well actually its 68x42mm not 68x46mm. That 46mm will not fit for sl6
mushroom
by mushroom
well actually its 68x42mm not 68x46mm. That 46mm will not fit for sl5
cerro
by cerro
mushroom wrote:
Fri Jun 07, 2019 2:51 pm
bb30 is 68x42. PF30 is 46mm. 2 standards.
/jonas l
mushroom
by mushroom
cerro wrote:
Fri Jun 07, 2019 6:42 pm
OH, my failure, sorry for that.
basicly one of theese will fit with 30 m axle for tarmac sl5, im i right?
cerro
by cerro
both PF30 and BB30 are for the same cranks yes.
/jonas l
