2021 S-Works Tarmac SL7 Warranty Replacement (was 2019 SL6 Disc)
tonytourist
by tonytourist
My wheel changes have been easy with both the standard and direct mount hanger.
Calnago
In Memoriam
by Calnago
^ Then your frame doesn't have the issue in the first place. And that's exactly what I would expect... wheel removal should be the same with either DM or STD mount hangers, so long as the derailluers end up in the same place. And if your wheel was difficult to remove with the standard hanger and b-link, then it will be difficult with a DM hanger as well. Unless mods were made with with initial setup (which is possible and easy) or the DM hanger was designed to take that particular frame's peculiarities into account, and positions the derailleur slightly outside of Shimanos specs to accommodate it.
tonytourist
by tonytourist
I have the exact same bike as Rich, I'm not pdlpshr :roll: :roll:
Calnago
In Memoriam
by Calnago
Yes... I realize that. So...?
Rich_W
by Rich_W
excuse the lawn
gurk700
by gurk700
HOT. (but i'm partial to SL6 :P )
are those 28mm turbo cottons or 26mm?
I've been running 24mm Veloflex and 26mm Turbos.
Wanna also try turbo cottons. Can't decide if I should get 26 or 28.
Rich_W
by Rich_W
26 turbo cotton. Measure 27.9mm on CLX50s
Jorisvc
by Jorisvc
Hi Rich,
Are you using cups on the original ceramicspeeds to fit the r9100?
No cracks?
Grtz
Rich_W
by Rich_W
Jorisvc wrote:
Wed Apr 24, 2019 2:01 am
Hi Rich,
No cracks?
Grtz
No, adapter cups are doo-doo. Using a proper Ceramic Speed BB30 Shimano Road Insert.
zerort
by zerort
Is this cheating?
Currently running 48/18 gearing but 46/16 also fits.
Ritsuke
by Ritsuke
Is the direct mount hanger also for the SL5?
Current: 2019 Specialized Allez Sprint Red Hook | SRAM Red Etap | FFWD F6R - DT Swiss 190 Ceramic hubs
Projects: 2021 TT Project | Frame Unknown | Shimano Dura-Ace Di2 | Pro Disc - TriSpoke
DartanianX
by DartanianX
Ritsuke wrote:Is the direct mount hanger also for the SL5?
No. There is only a TA direct mount hanger available, & as the SL5 is QR only... no luck I’m afraid.
Ritsuke
by Ritsuke
Okay, thanks for the answer! :)
I'll wait until I upgrade to SL6 than. :p
GeeTee
by GeeTee
Hi Rich, stunning build. Really liking your choices. (I also didn't hate the brown bar tape ;-) )
I've got an sworks sl6 disc incoming that I'm building up. I'd like to run 30mm GP5000s on the CLX50, but I'm concerned about clearance issues, both in width and also height.
Your Challenge 30s like tight behind the seat tube and, I'm guessing, also under the fork crown. How wide do yours measure up and have you ever had any issues with picking up stones that have scratched your frame at those points?
EDIT: I'm also looking at Hunt's new Limitless wheels (48mm deep and 34.5mm wide) and Light Bicycles Falcon Pro WR50 (50mm high and 32mm wide).
Rich_W
by Rich_W
Strada Biancha 30s are a bit tight but do clear. Lately been running corsa graphene 28s.
