Campagnolo 12 Speed Cassette
lowther
by lowther
I currently have the Campy EPS v3 Super Record groupset (11 speed). Does anyone know if the following set-up will work:
- 12 speed super record cassette 11-32
- My current Super Record EPS v3 rear derailleur modified with a Ceramicspeed OSPW cage
- 12 speed chain
Need the additioonal low gears for the mountains (29 just won't do it at my age).
Thanks
Ebruner
by Ebruner
In a word. No.
-Eddie
mag
by mag
Current EPS V3 RD is officially limited to 29T sprockets (12-29T) however you may have success with the Shimano or SRAM 11-30T cassette (or perhaps even 11-32T if your RD hanger is longer). Still you'd do it at your own risk.
If you aren't already at compact chainrings that's the safer way to go.
joeyb1000
by joeyb1000
I’ve gotten the derailleur (w/o OSPW) to handle a 32, but it’s not great and I don’t think think you get enough chain to handle all the combinations. The length of your hanger is a factor. So you need to test it yourself.
I don’t expect any problem with the 12s chain and cassette, except that you will only be able to use 11 of the 12 sprockets.
jih
by jih
You won’t be able to shift 11 of the 12 cleanly since if distances between sprockets has been reduced to fit the extra one in.
Alexandrumarian
by Alexandrumarian
Get a centaur 11-32. It is a boat anchor but shifts as well as SR and its dirt cheap. If it doesn't work well at least you didnot spend a fortune.
Calnago
by Calnago
Are some of you not even reading the first sentence in the OP’s post?.... he’s asking about using a 12sp cassette with an 11sp EPS group. Whether or not the derailleur has the capacity to handle the 32 cog is irrelevant.
Alexandrumarian
by Alexandrumarian
I offered an alternative that might work...
Butcher
by Butcher
Calnago summed it up correctly.
I think anything can be done, but it would first start with someone that can hack the electronics and can code it to shift 12 gears.
Miller
by Miller
I'm sure people read the OP's post perfectly well but wondered how he thought that EPS 11sp would manage to shift chain across a 12sp cassette and concluded that the actual want might be EPS with a 32 sprocket.
