English/Italian Thread Compatibility.
tabl10s
by tabl10s
What's needed cranks that are BSA with a frame that's Italian threaded?
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
ultimobici
by ultimobici
If the cranks are for English bb then all you need are Italian threaded cups.
alistaird
by alistaird
Do you mean BSA30? Then any Italian threaded external 30mm cups. E.g. rotor, tune etc.
tabl10s
by tabl10s
How much weight do they add? Should I just get cranks that'll fit without modification?
2018 Rca
alistaird
by alistaird
tabl10s wrote:How much weight do they add? Should I just get cranks that'll fit without modification?
I don't understand your question... What cranks do you have and what frame? Pictures might help as well please...
tabl10s
by tabl10s
alistaird wrote:
Sat Oct 27, 2018 8:45 pm
[/quote
Storck cranks(THM)for Pinarello.
2018 Rca
AJS914
by AJS914
THM's site for the Clavicula crankset says:
fits any frame with standard 68 mm BSA shell. Available for BB30, BB30A, Pressfit30, Shimano Pressfit, Italian threading, BB386 EVO, BBright™-Pressfit
It sounds like you'd need their Italian threaded cups.
tabl10s
by tabl10s
AJS914 wrote:
Sat Oct 27, 2018 9:34 pm
Thanks.
2018 Rca
ooo
by ooo
https://www.starbike.com/en/thm-carbone ... clavicula/
THM Carbones bearing cups for Clavicula
road and dp 68 cranks ITA
MPN: 20100002 Year: 2017
79.83 €
ready for sending in 4-6 business days
Bearing Shells ITA
Bearing shells with Italian thread sold with bearings, compatible with Clavicula SE and Clavicula M3 Road.
Color: Black
SKU: 20100002
https://www.starbike.com/en/ceramicspee ... m-bracket/
ITA30 red
MPN: CS-35
EAN: 5711050001576
226.05 €
ITA30: CeramicSpeed Bottom Bracket, which converts Italian-threaded frames with external bearing cups, originally designed for 24mm axles to now fit BB30 cranks with 30mm axle. Note that not all BB30 cranksets are compatible with this system. Examples of cranksets that are compatible include Rotor 3D+, Rotor 3DF and Zipp. Does not accommodate Campagnolo Over-Torque, THM and FSA386. This bottom bracket is offered with standard or coated bearings, and finished with red or black cups.
https://www.starbike.com/en/rotor-ita30 ... -road-ita/
ROTOR ITA30 bottom bracket road ITA
steel 30mm axle black
MPN: C04-023-01010-0
EAN: 8434366003412
46.22 €
alistaird
by alistaird
The only thing I found fitting 30mm cranks to an Italian BB is that the shell is 2mm longer and you need to look at the length of the crank. You need 70 +7+7+seals and a bit more with ITA shell and external bearings where the sun's are 68+7+7+seals and a bit more with English BB. I've not looked at how the THM's allow for the 2mm difference?
A
Sent from my CLT-L09 using Tapatalk
