Super record 12 brakes
markyboy
by markyboy
I thought 25s are now the norm
Colnago master with campagnolo super record 12
Pinarello f8 with dura ace di2
Eddy merckx 69 ultegra disc winter bike ultegra r8000
AJS914
by AJS914
Those 25s often turn into 28s or larger on wider rims and people like to put them on bikes designed for when 23s were standard. Every bike I've owned has had brake bridges on the lower side such that the pads on my Campagnolo brakes are always pushed up near the top. If Colnago had given me 2mm extra clearance on the brake bridges I could fit those 28s on my C59 but I'm limited to about 25-26mm actual width in order to have good clearance.
I'm not trying to make excuses for Campy. It seems that they dropped the ball a little bit here. The new 12 speed brakes should have more clearance than the 11 speed brakes designed 5 or 10 years ago not less.
mag
by mag
Take measurements of that washer and try to find a thinner alternative. Or file down the original ones, then polish and repaint that.
markyboy
by markyboy
mag wrote:
Thu Oct 25, 2018 8:10 pm
Yes thats what im going to do,is it possible to use a flat washer or do they have to be concave?
AJS914
by AJS914
Without a concave washer you can't angle the brake pads. You could file them to a slight angle though.
Calnago
by Calnago
^This. If it’s the conical washer I’m thinking of, which the rounded face of the brake shoe fits in, then that is absolutely a critical component to have in place in order to be able to perfectly adjust toe-in, and the vertical angle of contact as the brake pad meets the rim. Without that I could only guess that dialing in optimal brake performance would be next to impossible.
Or is there another concave (I’d say it’s conical but I think we’re talking about the same washer here) washer somewhere that you’re talking about?
As for standards as to where brake mounting holes should be drilled in relation to the wheel, etc... lol... yes, there are/were guidelines, but it’s a crap shoot as to whether any manufacturers really care any more. It’s largely a free for all. It’s really up to the buyer to make sure everything works well together if you’re buying anything other than a complete bike these days.
tommasini
by tommasini
To the OP - how about a picture showing how high up in the slot the pads are. While your issue is the 2018 vs earlier caliper design, I wouldn't be surprised if your pads are up high in the slots which would indicate that your brake bridge is way low thus thats the starting point of the real problem
(but you cant change that as we know).
My first suggested bandaid would be to add a second (or 3rd if possible) serrated washer which brings the rear caliper out a bit and therefore it comes away from the wheel a bit.
markyboy
by markyboy
@tommasini
Good point if i remember the caliper bolt came out the box with 2 x washers on them,i have never seen that before so i took one off.
When i get home from work ill try it.
