Dura Ace 9000 pedals - 4mm Longer axle option??
hismaimai9999
by hismaimai9999
Shimano offer the DA 9000 pedals with a 4mm longer axle over standard.
How do you determine if a rider needs a longer axle and can it be measured before purchasing? Is there a certain pelvis width that dictates a longer axle?
I'm unclear.
Thanks
Công ty rut ham cau quan go vap giá rẻ dịch vụ rút hầm cầu quận gò vấp uy tín
toiyuet
by toiyuet
If you have a pair of big foot, your shoes may not clear the crank......that's why Shimano make this version.
DJT21
by DJT21
I guess they'd be useful to help your heel clear the crank arm/chainstay if you've got flat arches/duck feet.
kwakekeham
by kwakekeham
I had a bike fit and using the knee tracking in video they indicated I needed 6mm wider axles. We shoved the cleat as far to the sides as possible to check that there was an improvement and there was but software still indicated 3 and 5mm I believe. So... bike fit will tell you.
Numbness in my right foot in the shoes have almost been completely eliminated as a result where I thought I needed new shoes.
