Full length fenders on a fork that's not drilled at the crown
A gigantic catch-all for Randonneuring (Audax), Bike-packing (Touring), and Commuting.
jever98
by jever98
I’d like to fit permanent fenders on a cross disc fork, which has QR drop outs. I can attach the fenders at the drop outs, no problems there.
The snag is that it isn’t drilled at the crown, so I don’t know how to attach it there. I thought maybe there is a way to attach something to the fork crown race?
If possible, I’d like to avoid using something like race blades or Crud Catchers.
Thanks for tips!
No longer in the industry
sqber
by sqber
Drill 4 holes into the fenders (2 at each side) and attache with zip tie to the fork. It will look something like this: https://i1.wp.com/buckyrides.com/wp-con ... .jpg?ssl=1 (minus the crown attachment).
onemanpeloton
by onemanpeloton
in my experience, crud catchers are crap but raceblades are pretty decent.
attaching fenders to the dropouts is a nightmare if you have to fix a puncture
2020 Trek Boone
2017 Merida Reacto
2017 Trek Superfly AL
mattr
by mattr
P clips at the dropouts.
Anything else is a pain in the arse.
It the bottom of the crown hollow? Or is there a hole in it?
jever98
by jever98
Here some pictures of the fork. I guess I could buy a fork that is drilled, but it would be unpainted - sniff. Drilling it and epoxying a nut in seems dangerous.
mattr
by mattr
Nah, no need to drill. Was actually looking for a hole in the bottom of the crown. A lot of forks have them.
Just drop a penny washer and ~30mm long M4 bolt down, so it sticks out the hole, then use the hole in the guard and another washer/nut to clamp the guard to the crown.
Dependant on you having a bung in the top, not a star washer!
jever98
by jever98
This one unfortuntaly doesnt seem to have a hole there :-(
mattr
by mattr
it'll be bigger p-clips then :/
sqber
by sqber
I still think that drilling the mudguard is the easiest and most effective way. The principle can be seen on these pictures, but instead of the short mudguard, you have the long one.
If you don't want to drill the fender and use cable ties, try glueing some heavy duty velcro at the bottom of the crown and on the fender?
This CX bike has no holes for full fenders, but with some thought and engineering, it has full fenders attached. And you should avoid using QR dropouts!
PS. Try using "rotate" function on your pictures next time :)
mattr
by mattr
https://www.sjscycles.co.uk/mudguards/1 ... ted-black/
Thats what you need rather than attatching to the drop out. Something like 17-19mm, just above the height on the disc caliper mount. Bend it so it fits tightly/flush. Bit of tape underneath to stop you marking the CF (as they will move/vibrate a bit during use)
An option could be to get some 22mm ones and flatten them out to fit at the top of the legs, then bridge between them/over the tyre, mount the guard to that.
(You can get the same clips much cheaper if you shop around)
NickJHP
by NickJHP
+1 on the zip tie suggestion. I've had mudguards zip tied on for decades without problem. Plus it's a lighter way of mounting than any other method.
