Gearing too high. Swap front or rear?
Beanicyclist
by Beanicyclist
Oh ok, I’d probably get the cassette then. You’ll find one for a decent price, just make sure that your derailleur can fit it. You can normally ignore all the limitations, so fitting a 28t on the rear should be ok. Check with your LBS maybe or try using a friends or improvising?
-BC
"Eat your green vegetables"- Peter Parker, 2004.
mattr
by mattr
alcatraz wrote:
Mon Oct 15, 2018 6:54 am
You might not think the 11t cog to be important now but get it anyway. If you someday get a compact crank you are going to wish you had.
11-28t or 11-30t.
/a
Nah, i got a 12 up cassette by mistake (mispackaged) rode around with it on a compact for 2 years, didn't notice up until i came to replace it and couldn't remember what i'd bought, had a closer look and realised it wasn't the 11 up i usually ride. That includes a lot of (very) fast descending and fast road work.
All depends how good (or otherwise) you are at higher cadences. Or judging when a tuck will be faster than pedalling.
On a bigger cassette, the extra mid cassette sprocket is more useful/useable than an 11 as well.
alcatraz
by alcatraz
The difference between 12t and 11t is 9%. It's a nice contribution to your range which helps when you tour or go climbing at lower cadences. If you never use it then you could just put a 46t chainring on and get smaller jumps on the whole cassette and easier front shifting. (Just an idea. :))
If you are doing flat roads a lot then 12-25t cassettes make a lot of sense so you can dial in the cadence perfectly.
The 16t cog is sacrificed in most cassettes over 12-25/12-27t. The jump from 15t to 17t is 13%.
Some people dislike a jump of 13% instead of two 7% jumps, but some people dislike the loss of 9% range. I happen to be in the latter group, mattr is in the first.
Just an interesting little sidenote is that 9% loss in range is about the same loss of range that a 2.5t reduction on your largest cog would do. Some people upgrade cassettes to obtain less than that (28-30t).
Svetty
by Svetty
853guy wrote:
Sun Oct 14, 2018 10:51 pm
Svetty wrote:
Sun Oct 14, 2018 10:32 pm
The 7800 series official maximum cassette sprocket is a 27T. A 28 will work OK but a 30 might be pushing it......
Hi Svetty,
It won't be Dura Ace 7800, since I can't find any 12-27 cassettes in any case, and the ones I can find are limited to 12-21.
The honour instead will go to good ole' Ultegra 6700, which are plentiful, cheap and to be honest, indistinguishable in shifting quality and real-world weight to the 7800 ones - to me, at least.
Best,
853guy
I meant the mech capacity not the cassette.....
853guy
by 853guy
Svetty wrote:
Mon Oct 15, 2018 1:12 pm
Hi Svetty,
Best,
853guy
Ah, yes, okay, that does indeed make sense.
Like you suggest, I'm also hoping a 28 will be fine but will be checking with a LBS to ensure whatever ends up going on works.
Thanks for the clarification.
Best!
853guy
