Sub 350 clincher rims
ergott
by ergott
I'd look into a 35mm carbon clincher rim for balance of lightweight and stiffness. Should be closer to 410g that way.
https://www.lightbicycle.com/700C-V-sha ... tible.html
Coinmonger
by Coinmonger
ergott wrote:
Mon Oct 01, 2018 5:02 pm
Thanks .So summaring :i should go for rims around 400g each .Ed hubs as in post above and sapim spokes (most important would be rear hub which should have at least 18 mm axle and triplet bearings.(still i AM thinking about shallow rims )
Coinmonger
by Coinmonger
That would give me relativly durable Wheels (not ultralight but light and durable enought ) besides till next summer im going to be 10 kg lighter.I just Hope this will hold up for this season :) :D :thumbup:
morganb
by morganb
kavitator wrote:
Mon Oct 01, 2018 3:44 pm
24/28 spokes
Aivee ED1 hubs are durable and good weight250grams for set (DS flange is 18mm from center)
Rim under 450grams will be too flexi
Do you know of any US distribution for these? These look like a dream hub looking at geo and weight.
ooo
by ooo
385g deep tubeless carbon clinchers on ali express
http://ali.pub/2sc9ui
ergott
by ergott
I would love to see those rims on a corrected scale to prove that claim.
Coinmonger
by Coinmonger
Ergott i might condider to buy them but 42 it seems a bit too deep .Perfect would be between 30-40 mm deep so im more convinced to go with yours or something similar
mattr
by mattr
Marin
by Marin
ergott wrote:
Tue Oct 02, 2018 12:04 am
Seems the weight is correct, the built wheels are also very light. It's a disc only rim though, and they don't seem to have light rim brake rims.
Eie carbon is currently the lightest option for rim brake clinchers. They only list the 60mm in superlight, but they can do the other heights too, I got a 40mm.
ooo
by ooo
380g 28mm tubeless rim with 22mm inside width:
https://www.lightbicycle.com/29er-disc- ... bikes.html
Multebear
by Multebear
ooo wrote:
Tue Oct 02, 2018 10:18 am
This rim is for disc, no?
ergott
by ergott
Marin wrote:
Tue Oct 02, 2018 8:34 am
I'd still like to see weights on a scale. It's far too common for components to come in more than claimed. Have you seen either their wheels or just the rims weighed?
For reference, Enve 3.4 disc rims are 390g and 397 grams respectively. I have found Enve's claimed weight to be pretty much their average so some lighter and some lower.
For rim brake their 2.2 rims are 410g and the 3.4 rims are 432g and 439g respectively.
Marin
by Marin
ergott wrote:
Tue Oct 02, 2018 1:12 pm
I'd also like to see the rims weighed of course, but my experience with Chinese vendors is that - unlike with bigger Western brands - the weights are always correct for some reason.
bm0p700f
by bm0p700f
Why would you ride in 80kph winds. That makes no sense. In winds that strong the last and only time I experienced them on a bike I was all over the road. Hense you remove riding in gales my statement makes more sense.
silvalis
by silvalis
bits of trees and other things start flying around at 80kph...
Chasse patate
