New Cervélo Tomorrow? (1st Oct launch)
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
A local Cervélo dealer has posted some Cervélo teasers about a bike they can’t reveal until tomorrow (1st Oct):
https://www.instagram.com/p/BoWASmigZ7n ... nyde2fvkdf
Anyone got any insight?
Shrike
by Shrike
Can only make out the depth of one wheel, but yes that's probably it 8)
Hype!
VTR1000SP2
by VTR1000SP2
Yep, new S series bikes are officially released tomorrow
RichTheRoadie
by RichTheRoadie
Ah, that would make sense.
rexyi1990
by rexyi1990
looking forward to it!
RichTheRoadie
by RichTheRoadie
Just seen the email from Cervélo. What an ugly front end...
tabl10s
by tabl10s
RichTheRoadie wrote:
Mon Oct 01, 2018 5:18 am
Are you talking about the bike or reviewer? The music is crap too.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
eric01
by eric01
polarizing to say the least. I happen to quite like it.
"Claimed weight for a bare 56cm frame is just 740g" is impressive. I wonder how much the fork and stem/bar weigh?
The shots from cyclingtips look really nice. Unfortunately the sunweb announcement looks way out of proportion.
https://www.cervelo.com/team-announcement
ill principe
by ill principe
Due to pricing, I was more interested in the new S3 and the fact that Cervelo stuck to the high and short geometry is a deal breaker for me. 605mm stack and 396mm of reach for a 58...
The question mark regarding tyre clearance for both the S models (from CyclingTips article) is also strange. Tire clearance with 25mm seems tight.
mrlobber
by mrlobber
For those wanting more traditional thru-axle systems, there will also be a threaded axle with a flush, tooled head available aftermarket.
Yes! Hope that one fits R5 as well, which would allow to drop at least 30g from the anchoring RAT axle setup.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
TobinHatesYou
by TobinHatesYou
740g for a minimally painted 56cm aero-disc frame is astonishing. Sounds too good to be true. Sunweb should easily be able to get to the 6.8kg lower limit assuming the seatpost and bar/stem combo aren't too chunky.
jlok
by jlok
tire clearance?
TobinHatesYou
by TobinHatesYou
Looks like the real frame weight is somewhere around 975g for a painted S5 frame.
https://www.cervelo.com/media/gene-cms/ ... _paper.pdf
TobinHatesYou
by TobinHatesYou
jlok wrote:
Mon Oct 01, 2018 9:10 am
tire clearance?
30mm official (38mm at the chainstays with ISO mandated 4mm clearance on either side.)
