Caad9 which year? Worth to build up? Need advsie
centurionAL
by centurionAL
Dear friends,
I came across the below frame and was wondering which year it's from and is it worth a ww build. Does someone know the weight?
Thanks all in advance!! ☺
Squashednuts
by Squashednuts
If you search 'CAAD 9' on this site you should find the frame weight and a few builds
Is it worth a WW build?....depends how low you want to go
6.0 to 6.5kg seems easily achievable from looking at the site
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
centurionAL
by centurionAL
Thks for the input!!
morganb
by morganb
They are great biked if not a pure WW bike. I raced one for two years and kept the frame even though it has been sitting unbuilt for a while. Too good to get rid of and the last of their US made bikes.
Rascal
by Rascal
I’m still running my CAAD5 7UP Team frame (2003?). 16.5lbs as seen here without serious focus on being WW... Looked into the year built, its a 2002 http://autobus.cyclingnews.com/tech/200 ... /7up.shtml
I bought it new as a frame as I was a team member of the amateur division of 7UP Nutrafig.
-Giant TCR
-CAAD5
-Klein Rascal
mpulsiv
by mpulsiv
Keep in mind that older frames have limited tire clearance (e.g. 25mm tires may rub between chainstays).
KC
by KC
That’s a 2010 with bb30. Also I have Caad 7,8 and 9. All of those take 25mm tires no issue. All are 13lbs built. Give or take. Great bikes.
RussellS
by RussellS
mpulsiv wrote:
Sun Sep 09, 2018 6:50 am
CAAD 7 and 9 can easily fit 28 and 30mm tires. The only way a 25mm tire would rub the chainstays is if you had NO bearings at all and the hub shell just wobbled side to side, left and right, up and down, on the axle. I own a CAAD 7 and 9. Aluminum frames from long ago. British threaded bottom brackets. I have Continental Grand Prix Four Seasons 28 on the back of the CAAD9. And 23-25-28 Michelin, Vittoria, Specialized tires in the other spots. Can't read the labels anymore to see what the official sizes are.
mpulsiv
by mpulsiv
That’s good know because this is not the case with older SuperSix frame.
themidge
by themidge
mpulsiv wrote:
Sun Sep 09, 2018 9:58 pm
Just a POI, I can fit 25's in my first gen. supersix, I think it's the 2nd and 3rd gen. ones that have issues.
Bluechip
by Bluechip
I've got an '09 CAAD9 with a standard bb. I have Farsport rims that measure out at close to 29mm wide with 25mm gps4000's that measure out at just under 29mm. No problem at all. At least with the frame. I had to find other brakes (Tririg) that would comfortably fit.
mpulsiv
by mpulsiv
themidge wrote:
Sun Sep 09, 2018 10:25 pm
25mm is bare minimum these days. My point is - don't invest into a frame that can't clear at least 28mm tire.
abelincoln
by abelincoln
My CAAD9 ran 25s on wide rims (Belgiums) with no problem. I’m sure they measured our larger.
shoemakerpom2010
by shoemakerpom2010
My SystemSix 2007 has a Caad 9 rear triangle and I run 25mm Conti IIs no problem....28mm Conti II after inflation would not fit.....
kman
by kman
Maybe not WW build but that will be an awesome, racy bike. Great frame.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
