Light disc wheels
jdess123
by jdess123
Looking for suggestions for a good, light (of course) medium depth carbon clincher wheelset for disc bikes. Maybe 35-50mm depth, around 1500g or less if possible.
wpccrunner
by wpccrunner
Industry 9 has a few new sets
i9.35: 35mm depth, 1355g, clincher
i9.45: 45mm depth, 1495g, clincher
Bontrager Aeolus XXX 4: 47mm depth; 1455g, clincher
theres a got to be a lot more options out there
spdntrxi
by spdntrxi
Roval CLX50.. low 14's as well
NealH
by NealH
The Roval CL(X) 50, or the CL(X) 38.
MRM
by MRM
I think at 60 mm (clincher) the Bontrager Aeolus 6 xxx are the lightest at 1530g.
Roadsailor has 60 mm clinchers at 1485g, but no one seems to have ever tested them.
morganb
by morganb
If you want something less conventional, MCFK 45 or 55 are in the mid 1300-1400g range and tested well aero wise in the tour test.
bm0p700f
by bm0p700f
TobinHatesYou
by TobinHatesYou
Advertised weights almost always don’t include the weight of valves and rim tape or proprietary rim strips in Bontrager’s case. One of the only brands that includes all of that in its advertised weights is Zipp, and they are spot on.
Klaster_1
by Klaster_1
A shameless plug, but my wheels came out at ~1206g: 46mm tall, 28mm wide, clinchers. Parts are Extralite CyberHubs, Light-Bycicle RR46C02, Pillar X-TRA Lite Ti and Pillar DSN, add ~100g if you want CX-Rays and ~50g for wider, taller RR56C02.
jhalmar
by jhalmar
My Roval CLX 50 disc wheelset is 1416g (front 650g / rear 766g) with original tubeless valves and rim tape.
shoon
by shoon
If I have the money, I would like to try out the bontrager Aeolus XXX4. Seems light, aero and good in crosswind
Enve is generally light but ex. If u choose that, go for the carbon-ti hubs. Much cheaper than their carbon hubs
moyboy
by moyboy
Using MCFK 35 clinchers with extralite hubs, been to italy with them not an issue, also weighs ~1200 grams and my day to day set.
vanmatthew
by vanmatthew
How aero are the MCFK 35 clinchers? Do you have anything you compare them to? People mention the tour test but I can't find it.
bm0p700f
by bm0p700f
I don't think they are very aero. First of all they are not deep but hambinis blog is revealing. Very blunt rims like these don't deal with changes in yaw angle well. Even on a straight road the yaw angle is always changing. With blunt rim the flow seems to separate and not reattach leading to extra drag. I suspect youll have a more aero and therefore fast wheel with the kinlin xr31t disc brake rim even though it 130g heavier than the MFCK rim.
Physics is cruel but true.
