What cables do I use for Sram Red?
wilwil
by wilwil
It seems difficult to buy Sram cables in the UK do people use Shimano? I think the gear inners are a different size by 0.1mm.
jobvisser
by jobvisser
Shimano cables work just fine for me
---> :oops: Send me a pm to order world's lightest low carbon fiber dust covers! (1g) :oops: <---
wheelbuilder
by wheelbuilder
Sram specific cables feed through the shifter much easier. If you can find them, use them. Jagwire makes 1.1mm cables.
Bluechip
by Bluechip
While I have used 1.2mm on Sram and it worked fine, the correct 1.1 cables are much easier to install.
motorthings
by motorthings
yokozuna. best mod to the system. been using them for years.
sungod
by sungod
wilwil wrote:
Thu Aug 30, 2018 2:45 pm
a quick search with google finds multiple uk suppliers, even halfords do them!
NiFTY
by NiFTY
They all work. 1.1mm are easiest to install. I use kcnc ti on the brakes without issues for thousands of ks but on the shift i have had both sides fail inside the shifter (so not over clamping).
