Trek madone slr 6 disc
Stitchking
by Stitchking
Kittel wrote:Next try with the picture.
https://weightweenies.starbike.com/foru ... w&id=70851
Thank you
Those are mounts for the reflectors that come in the box. You can get an adapter to run a flare r on the rear one(the one on the right) so dont toss that but the front one is basically trash. Keep the hardware for them as bontrager dont usually provide bolts with their blendr mounts and you can re use them. There should also be a little silver m3 bolt that will bolt that rear mount into your seatpost with the bike. Its in a big bag that has dont throw this out printed on it.
Sent from my SM-G935F using Tapatalk
Kittel
by Kittel
Thank you very much.
I didnt pay attention to the reflectors.
I thought, that they are for lights, but Trek also said that a light mount is integrated in the seat clamp.
Roadrocket
by Roadrocket
Looking for any infos about new Madone SLR.
I´ve just got an special offer at £4.5k for new SLR 6(Ultegra equipped rim brake option) at my lbs https://www.trekbikes.com/us/en_US/bike ... lity_black
Any thoughts about frame weight, BB and front end stiffness and overall ride quality? It is still so much money to spend compared to let´s say Cervelo S5 2018, now at £2.6k.
Thanks for all inputs!
harvsurrey
by harvsurrey
If your looking at 2018 bikes compare it to a madone 9.0
I have one , love it to bits Image
Sent from my SM-G950F using Tapatalk
Roadrocket
by Roadrocket
Real looker! I am looking at 2019 SLR 6, viper red colour scheme.
Do you have OCLV 700? How are you satisfied in terms of stiffness, weight, climbing abilities...?
harvsurrey
by harvsurrey
I have 600 not 700 OCVL , stiffness is good , I have the full aero bars and Di2 , all up weight including pedals and cages with my Enve see 5.6 is 7.8kgs
I am a 85kg rider so speed on hills is subjective as I run 11-32 cassette 50-34
Stitchking
by Stitchking
Roadrocket wrote:Looking for any infos about new Madone SLR.
Obviously my one is disc brake so it will be a little different in terms of stiffness, and the weight will be a little less on the rim brake frame. Its also 700 oclv so should be lighter than last years frameset, although i haven't looked into that one so dont quote me here.
Stiffness wise, the front end is a little flexier than a 2018 s5, but not so much that i find it detrimental. I've pulled a few 1500w+ sprints on it now and haven't noticed it flexing. Any flex is in the bar too, the headtube is really stiff so cornering is super direct. In the same situations bb is super solid. It is a very stiff bike.
In terms of ride quality, the isospeed works. Very compliant back end. The bars have enough of a dampening effect to balance it all out. I'm very impressed. I currently commute on mine as i can't go back to my old commuter after riding it.
£2600 for an s5 is damn cheap though, it just won't be as comfortable and a maginally less aerodynamic.
Roadrocket
by Roadrocket
Thank you both for inputs.
So what do you think about price, should I get it for £4.5k?
£2.6k for an S5 on Ultegra is a cracking deal, but I think I am between 54 and 56.
Madone is clear choice with 56, btw I am 6ft with 33.5 inseam.
Stitchking
by Stitchking
I hd to get a longer seatpost at 6ft on a 56 frame, so may cost you a little extra there. Saddle height of 785. Om not sure about the exchange rate but thats more than retail here in nzd im pretty sure
ryanw
by ryanw
I’m 6ft on a 56cm S5. BB to saddle is 765mm (short legs). 120mm slammed -12° stem.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
Roadrocket
by Roadrocket
Stitchking: my saddle height is 745mm so should be ok. RRP of Madone SLR 6 should be 6300usd according Trek site. If you are right about price, I´ll order one from NZ :)
Edit: you´re right, I don´t know why, but pricing in NZD is really much lower: https://www.trekbikes.com/nz/en_NZ/bike ... ne/c/B213/ it should be about £4200 RRP, maybe different VAT
Roadrocket
by Roadrocket
ryanw wrote:
Sun Oct 28, 2018 10:29 pm
I have shorter legs(745mm saddle height) so I wonder if 54 would be better fit. I´ve just read your S5 topic, really great looking bike, I am sorry for your accident and glad you´re ok.
BTW, do you remember your 56 S5 seat tube lenght? I cannot find it in any geo chart.
Steph26ne
by Steph26ne
Hi,
Any advice for sizing? I’m 6’ (183cm) with a saddle height of 76 cm. Inseam 86 cm. No test bike avalaible 🙁. Reporting from my Pinarello F10 55 (110 stem, handelbar stack 90) give me a 56 but reseller tells me 58
Tx
Mep
by Mep
Stitchking wrote:
JScycle wrote:
Mon Aug 20, 2018 5:22 am
Stitchking wrote:
Mon Aug 20, 2018 4:38 am
What is this piece?
Thats 10g of steerer tube i cut off the fork
Did you cut the steerer at the prescribed 5mm below top of stem?
From what I'm measuring, that's going to be too little. The integrated space within the stem is 3mm, and the expander is 2mm thick. That alone is 5mm with no space to preload the bearings.
Stitchking
by Stitchking
No i cut it roughly flush with the top of the stem, then i have a 5mm spacer, which with the expander in the steerer was about perfect. Just fiving myself potential room for fit and resale
