Dura-Ace 9070/9100 & Oversized pulley
Ritsuke
by Ritsuke
I've found an OSPW system I'd like to use/test but I'm not sure about the fitting. Is there any difference between the 9070 (Dura Ace Di2 group which I have) and the new 9100 rear derailleur? The OSPW is designed to fit on the new group but I'm curious if I can install it on mine.
Thanks for your advice!
S-Works Tarmac SL5
Retired: Specialized Allez Sprint Red Hook Crit
Klaster_1
by Klaster_1
I have experience with RD-9000 and RD-R9100 only, but cages of those are incompatible: RD-9000 guide pulley and cage pivot axles are not aligned on RD-9000 and aligned on RD-R9100.
Ritsuke
by Ritsuke
Thanks for the heads up. Decided to go with a design I like a little less but I'm sure it fits. Retour to China is a pain so I'm not taking the chance. :p
S-Works Tarmac SL5
Ritsuke
by Ritsuke
Allright, anyone have any experience with the Rockbros OSPW system? I can't seem to get it to work with 11-28 cassette. It keeps touching.
S-Works Tarmac SL5
ms6073
by ms6073
B-Tension adjustment? Also, if your bike does not have a direct mount derailleur hangar, I might suggest a Wolf Tooth Roadlink DM for a R9100 rear derailleur.
Ritsuke
by Ritsuke
I have the 9070 derailleur. B tension all the way in, chain seems right (normal length + 3). Still touches the cassette. I find it strange.
Any here ever installed one?
S-Works Tarmac SL5
Lewn777
by Lewn777
This is just my opinion.
Send it back and get your money back.
I've used oversized pulleys, from new they use nice slick bearings, but very quickly they wear out, plus you only gain a watt or two at most. Shimano bearings are much better for long term endurance. Plus oversized pulleys seem more likely to cause a mechanical failure and end up with your mech in your spokes and a long walk home. In my experience Wolf tooth type extenders make shifting slower and less crisp.
Probably best for a rarely used TT bike, and then it's probably unnecessary. If oversized jockey wheels were a real gain then SRAM, Shimano or someone else would have designed them in from new, as honestly it wouldn't be hard.
kode54
by kode54
are both pulleys oversized? some oversized pulley systems have a smaller 12 or 14T on upper and a 17T on lower cage.
makes room for larger 28-30T cassettes.
maybe you just need to replace the top pulley with a regular teeth one to prevent proximity to cassette.
Ritsuke wrote:
Fri Sep 07, 2018 8:00 pm
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
tabl10s
by tabl10s
Ritsuke wrote:
Mon Aug 13, 2018 10:15 am
I have a Ceramic Speed w/9070 without problems.
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
Ritsuke
by Ritsuke
kode54 wrote:
Sun Sep 09, 2018 9:02 pm
They are indeed both oversized, 17T. Rockbros OSPW.
tabl10s wrote:
Sun Sep 09, 2018 11:41 pm
Both pulleys oversized (17T) with 11-28 cassette? :)
S-Works Tarmac SL5
tabl10s
by tabl10s
Ritsuke wrote:
Mon Sep 10, 2018 9:47 am
Yes.
2018 Rca
