Ride with a loose headset: risk of some dangerous?
calpartz
by calpartz
Hi,
I rode some km (maybe 10-15) with a loose headset / with a play in the headset which I now fixed correctly.
Now, I have fear that I damaged in this way something, for example: the carbon-fork or the headtube because of the play.
What do you think about this? Do I have now to change the carbon-fork with a new one?
​​​​​​​Thank you and sorry for my english.
TobinHatesYou
by TobinHatesYou
No way for me to know for sure, but unless the whole steerer/headset assembly was super loose, the amount of travel and vibration was unlikely to cause significant damage in the distance covered.
calpartz
by calpartz
TobinHatesYou wrote:
Mon Aug 13, 2018 6:56 am
Thank you for this reply – which helps me.
The headset was just a very little loose in direction front/back. For this reason I did not noticed it before.
calpartz
by calpartz
Other opinions? Then Canyon would have to receive the bike back, what I wouldn't since there is no other same models to buy ...
NiFTY
by NiFTY
Just have a quick squizz at the fork. Unlikely to be an issue,
mattr
by mattr
Unless it's very loose and you've been doing huge jumps to flat the absolute worst case scenario is that you might possibly need a new bottom bearing.
If it's massively loose, how the hell didn't you notice as soon as you touched the bike. and adjust it?
I doubt canyon will be interested, IIRC checking headset adjustment is part of the normal pre ride/assembly check.
calpartz
by calpartz
NiFTY wrote:
Mon Aug 13, 2018 12:24 pm
It seems to me ok!
mattr wrote:
Mon Aug 13, 2018 12:42 pm
It was not so loose, that's because I did not noticed it before.
So, you mean that in the "absolute worst case", namely in the case that the headseat has much play / was very loose the carbon-fork frame would not have been damaged, right?
mattr
by mattr
If you were able to get on the bike and ride it without being scared for your very life by the amount of play in the headset, it'll be fine.
kode54
by kode54
if anything...bearing would take the grunt of damage. but i doubt it from what you're saying. are the bearings still smooth?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
jfranci3
by jfranci3
It's note great as you can damage the side of your headtube or put a score on your fork. As it gets loose, it'll feel notchy.
If goes full loose (lets say you break a spacer), I don't think it'll bind, as it doesn't have enough room. I think the worst cases are scoring your fork stem (which could eventually break, but I doubt it), breaking spacers, you hammer the bottom bearing into the fork, and destroying your bearings.
mattr
by mattr
Yeah. But it'd have to really loose for that. As in all but unusable.
A little bit of wobble isn't going to do that unless you run it for months or are using it as a trail/dh bike
bm0p700f
by bm0p700f
If you could ride the bike then you would not have damaged anything. Very loose headset means the bike is unrideable. You simply wont make it round a bend. I have had steerer/stem combinations that have refused to be without play and no damage has ever occurred. My single speed MTB always has a small amount of headset play so that fork is going in the bin but again no issues. If a carbon steerer headset bearings on an MTB that is ridden fast off road can survive I don't think your steerer is going to be under too much stress.
calpartz
by calpartz
Hi,
thank you everyone for the reply. This helps me much!
Anyway, I forgot to say that the headset is *without* fork crown race (https://imgur.com/a/RvcH4Bq): is this a relevant information for to answer my question? Is the answer the same?
mattr
by mattr
Yes
calpartz
by calpartz
mattr wrote:
Sat Aug 18, 2018 6:36 am
Yes
Thank you again. Now I can ride the bike without be worried!
Have a nice weekend.
