Anyone riding Argon 18 Nitrogen?
addicted
by addicted
Anyone riding this frame these days? Thoughts on sizing compared to other bikes?
I ride a 73cm saddle height, which seems to put me between a small and medium. I think I'd have to use their largest spacer on the small to get the bars high enough along with a 120 stem.
With the Medium, shortest spacer with a 110 stem, but not sure if the saddle will be jammed too far into the frame and look like a fred....
Any pics of your setups?
Thanks!
topflightpro
by topflightpro
I don't have a Nitrogen, but I have a Gallium with the same Headset system. My saddle is set at 75 cm, which puts me right at a Medium.
The geometries of the two are not identical, but they are similar. Even if I were to lower my saddle 2cm to match your saddle height, I don't think it would be too low. In fact, I'd go the opposite, a lot of seatpost with a big stack of headset spacers would look worse than low saddle and fewer spacers.
addicted
by addicted
Thanks, appreciate the info.
Do you happen to have a pic posted of your bike setup?
Renne
by Renne
I've been riding a Nitrogen for the last few years and it's a great ride. Aero, fairly light (for an aero bike) and pretty comfortable (I've ridden non-aero bikes much less comfy).
I'm 186cm with a 79cm saddle height. I ride a size large frame with the big spacer and a 110mm stem.
You can find several pictures of my bike on my Instagram page (www.instagram.com/francisrenne)
bacally
by bacally
Thanks for the info!
I want to tell you that the best playclub.uk.com.lucky.pants.casino be found here. I also improve my skills with each round right there. I'll play there next month, btw.
