Direct mount rear brakes for 28mm rims
epoklar
by epoklar
The last piece of the puzzle for my new chinese bike build are some dm rear brakes for my 28mm carbon rims. I can't seem to find any that fits.
I have tried the new sram s900, but no dice.
I have also tried Ultegra R8010-RS Direct with the thin shimano brake pads for carbon rims, but still not enough clearance.
Do the dura ace r9010 have more clearance than ultegras? according to the manual both should clear 28mm rims with the thin brake pads, but i'm not sure since the ultegras certaintly didn't.
prebsy
by prebsy
i was pretty bummed by this exact situation on my felt AR. I "solved it" by removing the conical washer behind the pad holder. It's not perfect but gets you an extra 1.5-2mm of clearance
Strava
Current Stable:
Specialized Allez Sprint Disc
Cervelo Aspero
Scott Spark 910 Contessa
wheelsONfire
by wheelsONfire
That seems weird. I have Easton Aero 55 (these were probably among the fattest when they came out) and the 2015-2016 EE brakes, not direct mount, but i have lots of clearance so i could probably use 30mm rims without issues.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
epoklar
by epoklar
wheelsONfire wrote:
Thu Aug 09, 2018 12:25 pm
I'm pretty sure the eebrakes will solve my problem, but they will, unfortunately, create a new problem, a financial one.
epoklar
by epoklar
prebsy wrote:
Thu Aug 09, 2018 12:22 pm
i was pretty bumped by this exact situation on my felt AR. I "solved it" by removing the conical washer behind the pad holder. It's not perfect but gets you an extra 1.5-2mm of clearance
I will try removing the washers.
bilwit
by bilwit
if you only need a few hairs of clearance, EE brakeshoes might do it. They have lower stack than Shimano or SwissStop shoes
Bluechip
by Bluechip
I've got some Farsport rims that are very wide. 29mm I think. I just got a set of Tririg Omega X brakes and they work great. Plenty of clearance with 25mm Conti GP4000s's measuring out at 30mm. No more shaved pads for me. Mine are regular mount but it is also direct mountable.
Jereb
by Jereb
Bluechip wrote:
Thu Aug 09, 2018 5:15 pm
Hi
Tririg worked on my 2018 AR 1 also.
The bottom mounts suck with dirt accumulation after a rain ride.
A TRP 860 have a lot of room but never used one yet.
Jere B
Beaver
by Beaver
It's really strange, that there are not many models for wide rims yet. Bontrager Speed Stop Pro would be another alternative.
I would wish for a TRP T980 in a SL Magnesium version - would be stiff, pretty and light.
kode54
by kode54
yeah. the very reason why my rear eeCycle rear DM brake failed.
I noticed some brake rub and looked and found the centering device tab broke off...rendering the brake to skew to one side. not sure how the warranty is on them, now that Cane Creek bought them out.
The entire assembly was so mucked up because of all the dirt and grime.
Jereb wrote:
Thu Aug 09, 2018 6:48 pm
Hi
Jere B
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
