spdntrxi
by spdntrxi on Sun Aug 05, 2018 6:57 pm
I know how boring ... another Parlee Zero this time XD. Frame had B.B. (105g) and hanger (?) so under 1kg for a medium with mix of UL and SL Parlee tubing
Stay tuned.. building in process.
spdntrxi on Wed Aug 08, 2018 1:25 am, edited 1 time in total.
LouisN
by LouisN on Sun Aug 05, 2018 10:28 pm
I was tired of the Z series 6-7 years ago ... just about every WW member seemed to have one
But I always find them classy and beautiful. A lot more than the "modern" Parlees.
Louis
spdntrxi
by spdntrxi on Mon Aug 06, 2018 1:15 am
LouisN wrote: ↑Sun Aug 05, 2018 10:28 pm
Louis
I know what you mean.. I cant quite stomach the Altum or Chewbacco however this is not going to be a true WW build.. More of a budget parlee build (after the frame anyways)
This will be my first stab at disc with a slight bias to gravel / fireroad type of riding... I hope to keep it in the 17-18lb range.
Enve G23 would be so nice... but I must resist.
spdntrxi
by spdntrxi on Wed Aug 08, 2018 12:58 am
Wheels...not light by any means
HED Ardennes LT tubeless
DT Swiss quick releases
Schwalbe G one speed 30c
The easiest tubeless setup I’ve ever tried
LEC135
by LEC135 on Thu Aug 09, 2018 11:30 am
Louis
I know what you mean but I bought a Z5SL and simply cant get bored of it. It's amazing and everything else I try just isn't as exciting. I've tried an Altum and it just doesn't have the same life in it.
spdntrxi
by spdntrxi on Sat Aug 11, 2018 8:38 pm
Headset cane creek ( I didn’t use most of it.. only 1 spacer actually )
Tune Gum-Gum / Extralite hyper top cap
Stem 120mm mcfk
I also have one of the Redshift shockstop stems that weighs more then the frame (really weighs 305g
spdntrxi on Wed Aug 15, 2018 2:00 pm, edited 2 times in total.
spdntrxi
by spdntrxi on Sun Aug 12, 2018 3:01 pm
rexyi1990 wrote:Hey, great component! Waiting for the bulid
Waiting for rest of the groupset to come in.. already changed my mind and getting the ultegra rx clutched rear derailleur
Thanks!
spdntrxi
by spdntrxi on Sun Aug 12, 2018 5:28 pm
Parlee FD Clamp and seatpost clamp
little lazy since I have post and angle perfect from the other bike.. I dont want to start all over.
Padded Berk Lupina 98g
Darimo 3K 31.6 /250mm Seatpost was 76g
Which leaves the other 50g being the Shimano battery and foam keeping it in there.
hydro lines and Di2 all ran through the frame already ... gonna be work to run everything and drill the Easton EC70 AX bars when they come in for the bar charger.
JScycle
by JScycle on Sun Aug 12, 2018 11:15 pm
spdntrxi wrote: ↑Sun Aug 12, 2018 5:28 pm
I think the only way the saddle will be the same angle as your previous bike is if it has the exact same seattube angle. This may not be the case
spdntrxi
by spdntrxi on Sun Aug 12, 2018 11:28 pm
JScycle wrote: ↑Sun Aug 12, 2018 11:15 pm
true and they are the same.
spdntrxi
by spdntrxi on Wed Aug 15, 2018 2:03 pm
ordered one of these.. should be roughly half the weight of the Parlee seat clamp. I will probably get their thur-axles at somepoint as well.
