S-Works Tarmac SL 6 (DISC) OSBB Dimensions for new BB
ergott
by ergott
Calnago wrote:
Thu Aug 02, 2018 3:26 am
@Ergott... the whole “OSBB” thing is a clusterf#%¥ of nomenclature. The Crux you are working on has the “old” OSBB with the narrower BB shell (61mm I believe). I worked on one of these some time ago. I used a Praxis BB but also had to use two 3.5mm spacers on either side of the shell to essentially widen it to the standard 68mm shell. All worked out fine. The narrower BB shell was a disaster as Specialized tried to differentiate themselves from Cannondale. A narrow shell with loads grinding away on the outer edges did not play well with longevity. Anyway, they’ve moved from that but I think they still use the “OSBB” term. Currently I don’t think they have any “narrow” OSBB shells in the lineup.
I understand all that, but the published timelines people refer to are wrong. The Crux I'm working on here is the current model.
https://www.specialized.com/us/en/s-wor ... 487-129101
The Tarmacs I've worked on are 2016 SL5. Both are stated as BB30 by BB literature everywhere. That's why I asked if anyone has actually measured the SL6.
The bearing to bearing measurement for the bikes I refer to is 63.5mm, not 61mm. This, just like when I build wheels, is why I measure stuff. So much misinformation online.
ergott
by ergott
.... duplicate
ergott
by ergott
Okay, one hypothesis I need help with. When you are talking about a 68mm shell, where is that measurement to? I installed this crank with the same amount of spacers and BB30, but I'm 100% positive the bearing to bearing measurement is 63.5mm. Is there some other way? I do notice that the shell is a bit wider and the bearings a a little recessed.
Siok
by Siok
Confusing indeed... just built my SWTarmac Disc for DuraAce 9100 Crankset... didn’t want To waste the ceramic bearings so I inserted Enduro Bearings 24mm adaptors for Shimano and so far it’s working wonderfully. Good luck.
mushroom
by mushroom
what bottom bracket would i need for tarmac sl5 s works year2015 if i wiuld want to fit quarq 30bb pf spindle/axel?
mushroom
by mushroom
ome rodriguez wrote:
Thu Aug 02, 2018 3:55 am
Correct. The current tarmac sl6 has 42x68mm bb shell.
what bearings i can fing on 30 mm axel?
like 5 maybe in whole market i guess.
and also https://www.c-bear.com/en/products/bott ... 30mm-rotor i guess.
