Sram/Shimano 12-speed cassette spacing compatibility?
NickJHP
by NickJHP
Does anyone know if the recently announced Shimano 12-speed XTR cassettes will use the same spacing as the SRAM 12-speed? With 11-speed, you can mix and match with impunity - I have a couple of bikes using SRAM shifters/derailleurs and Shimano 11-speed cassettes.
TurboKoo
by TurboKoo
I have measured them and they are not the same.
Unfortunately I cannot remember numbers on the top of my head.
Cannondale SuperSix
Shimano 9270
ooo
by ooo
numbers need some confirmation
12s shimano 3.55 mm
12s sram 3.65 mm
when cassettes aligned by first cog, mixing accuracy 0..+1mm
when cassettes aligned by middle cog, mixing accuracy -0.5..+0.5mm
TurboKoo
by TurboKoo
Thanks OOO
Now that I see the numbers again I recognize them.
Cannondale SuperSix
Shimano 9270
GlacialPace
by GlacialPace
That's a shame, it's always been good to know that they were the same, still it's probably choose enough to make it work?
ooo
by ooo
You can test quality of "0.5mm offcenter shifting" on your current bike by adjusting cable tension or changing di2 setup by +-3 steps of microadjustment steps
Anyone know Campagnolo 12-speed cassette rear cog spacing (center-to-center)?
vanmatthew
by vanmatthew
Interesting thanks. XTR 12 speed has not been released yet right?
ooo
by ooo
Shimano RD-M9100 + Sram Eagle 12s cassette + Shimano SL-M9100 12s shifter:
Shimano RD-M9100 + Sram X01 Eagle 10-50T 12s cassette + Sram GX 12s shifter:
bedampft
by bedampft
ooo wrote:
Tue Oct 23, 2018 9:35 pm
So XTR Shifter + RD with Sram cassette seems not to work properly because of the indexing on the shifter.
But it works with an Sram Shifter. Who would have thought that? :roll: But why even use a XTR RD in this case?
I don't get this whole "mixing parts up" thing anyway.
If you still what to use your shitty xD driver anyway, why not stick with Sram? Only because of the cheap, but maybe light and not reliable, rearhub you've got in your chinese wheelset?
bm0p700f
by bm0p700f
Shimano mech probably won't break as often as SRAM mechs.
TheKaiser
by TheKaiser
bm0p700f wrote:
Sun Oct 28, 2018 8:32 pm
Yeah, it does seem that Shimano RDs have a better reliability track record. I am pretty blown away by that second video though, as it implied that the cable pull ratio of the new XTR and Sram Eagle are the same, meaning a sort of return to cross-compatibility in one regard, even if we have lost cross compatibility with cassette spacing. That cassette incompatibility kind of sucks for anyone with a lot of wheelsets who might want to trade back and forth between bikes based on the tires/riding coditions, or if one wheel is waiting for repair and you want to keep the bike in service with a wheel swap.
Does anyone have cable pull ratio info yet? That cog spacing document was a sweet find, so something similar for the shift/derailleur system would be great.
Cycloholic
by Cycloholic
Anyone knows the cog width of eagle and shimano 11s?
kzy090
by kzy090
I've seen several Youtube videos that mix them up.
I think the dimensions are different, but they seem to work.
ooo
by ooo
measured cable pulls by io wa
rynogee
by rynogee
is anyone able to report any more real world testing on this. I've seen a couple of threads contradicting the videos in this thread (i.e. stating xtr 12sp RD adn shifter works with sram and sunrace 12sp cassettes). e.g. https://singletrackworld.com/forum/topi ... atibility/
I have a wheelset with an xd driver with little hope of a microspline freehub body in the near future (formula), plus some dt wheelsets I can put microspline on. Want to run xt or xtr shifters and RDs on the bike but have mutliple wheelsets in use.
i had several bikes previously with shimano RDs and shifters and sram cassettes in 11 speed with great shifting. Kind of also wondering if the shimano shifter in 11 speed mode would play with a sram 11 speed cassette or not, which might be a possible solution.
