Pinarello Dogma F10 Build / Finished
TonyM
by TonyM
syplam wrote:Nice bike. Which B.B. did u install? I’m thinking what I should get for my f10
Which groupset will you use?
DA, SR, eTap?
syplam
by syplam
probably Etap, trying to work out if I should use 9100 brakes or red brakes. I have etap plus 9100 on my giant and it seems fine but i dont know if the red brakes will be even better.
Sent from my SM-G9650 using Tapatalk
Stitchking
by Stitchking
syplam wrote:probably Etap, trying to work out if I should use 9100 brakes or red brakes. I have etap plus 9100 on my giant and it seems fine but i dont know if the red brakes will be even better.
Red brakes are garbage compared to 9100
Sent from my SM-G935F using Tapatalk
Jugi
by Jugi
Stitchking wrote:
Sun Jul 29, 2018 1:33 pm
When using SRAM’s levers, I’d say Red calipers are better because the cable pull is a bit different between SRAM and Shimano. All calipers are below average when mixing levers and calipers from different manufacturers.
F10’s forks have direct mount bolt holes on all models, right? Is there are direct mount SRAM Red caliper available at the moment? SRAM has a non-series direct mount caliper, or is it infact Red?
syplam
by syplam
F10 doesnt have direct mount, actually the difference in lever pull may be why I locked up my brakes and did a flip last weekend
aksinding
by aksinding
This bike is beautiful! I have a 2018 F10 Disk and this has inspired me to clean her up and shoot some pics. THANKS!
AdamKatzSinding.com
