Ryan Gets Trendy: Wilier Cento10Air Disc :shock:
pdlpsher1
by pdlpsher1
Are those a special version of the Bora, one with matching yellow paint?
If there's paint on the handlebar under the bar tape, you can stripe the paint to save a few grams.
liam7020
by liam7020
Very nice bike - could you post us another full length photo but a bit closer in with more bike and less wall/shrubs! Ta
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
spdntrxi
by spdntrxi
cant be bad at all.. lots of PR settings on your local hills with the new bike I see.
RyanH
by RyanH
Fat Diaries: Day #4
I decided to take off anything I could easily get access to and weigh it. Man this is bleak.
Top Cap and Bolt:
Alabarda Stem Wedge:
Front Thru Axle:
Rear Thru Axle:
Front Bora 50 Disc with 25mm Vittoria and H11 Rotor:
Rear Bora 50 Disc with Rotor and Chorus 11-29 Cassette:
Chorus doesn't belong here:
Super Record replacement with Token lock ring:
An enormously long chain due to OPSW:
Cut to size:
Seatpost Wedge:
Why.... The heaviest non functional cover in the world:
Off comes the OPSW:
Standard Super Record Cage:
SRM Origin ended up being heavier than expected. It's roughly 515g without rings vs my THM SRM was 460g:
Holy Mother of...
Ooooh, more Ceramic Speed goodies:
I have some work cut out for me...
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
jimaizumi
by jimaizumi
Not sure how you're going to get this thing purring like a kitten but I'm intrigued..
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE: :mrgreen: :mrgreen:
RyanH
by RyanH
@pdlpsher1
I think so, only because I've never seen them before.
@liam7020
I'll take come better shots with my real camera hopefully over the weekend before I head out on my work trip.
@themidge
Nice try...
Regarding the weight, on paper I could theoretically get this down to 6.5kg without going too nuts (so glepore's guess was right). Going all out while keeping the module (frame, fork, stem and seatpost) mostly intact, I think one could possible get it down to 6.3 or 6.2kg or maybe even 6.1, but that would require 845g Ax Lightness 24T wheels (not aero) but also almost 500g lighter by themselves.
I think the Ax Lightness 38T are a good fit for this bike. They were designed with CFD so at least they have /some/ attempt at being aero and they weigh a scant 1020g while being 26mm wide. I think those, along with a handful of other tweaks I have in mind would at least get me down to sub 6.8kg. I mean, common, I can't own a bike that's UCI legal.
Strava
mdeth1313
by mdeth1313
see if that boat anchor of a cover can be 3d printed
Speedplay is the devil!
RyanH
by RyanH
Already one step ahead of you:
What should I order to make a mold?
Strava
SLCBrandon
by SLCBrandon
Or just call it a loss and buy a rim brake XR4? 😁
spdntrxi
by spdntrxi
ryan you use the part to make a mold... you just cover it with a release agent and you might need some putty/clay. You tube is your friend. Search carbon fiber molds.. very common in my import rice rocket days.. I have not done it in years. But if I get a 2019 BMC TMR01, I will be tempted.
JScycle
by JScycle
If you can get the correct standard of thru-axles that's probably a 50g saving if you replace both.
I think you can easily get it to 7kg
Delorre
by Delorre
Glad that there a soo much places to save some weight. Biggest dissapointment for me are the Bora tubs : Those are boat anchors :shock: My complete Roval clx32 clinchers, incl rotors (160F / 140R), DA 12-25 cassette, etc is 2310 gr :wink: Even with the SR cassette on it, it's still 100gr more than a well set up clincher set :?
RyanH
by RyanH
Yeah, I'm not sure why they ended up being 150g heavier (estimated at 1360g) than the rim brake version, although that seems par for the course with disc wheels.
They're fantastic wheels though, just like the rim brake version.
Strava
joejack951
by joejack951
RyanH wrote:
Sun Jul 15, 2018 10:36 pm
There's a lot of 10-20% grades with stop signs in the middle that I generally just blow through...which is more or less russian roullette because I'm definitely not stopping in time unless I have alloy on that day.
Long story short, I'm viewing my jump to disc as a luxury item, not a necessity. Just a little nicer and convenient braking for my typical weekday rides.
I hear a lot about how carbon wheels brake acceptably with rim brakes. Is this considered acceptable? How many other disc-skeptics feel the same way about stopping?
