One thing I dislike with disc brakes
TonyM
by TonyM
Ok....I just found out that I could remove the lever from the thru-axle. Weight saving: 27g
LeDuke
by LeDuke
TonyM wrote:Ok....I just found out that I could remove the lever from the thru-axle. Weight saving: 27g
DT Swiss?
I haven’t used their TA with the removable handle yet. But, I’ll probably go that route on the disc road bike I’m planning. Assuming the same handle works on both front and rear, seems like a great place to save some weight without having to carry a 5mm or 6mm wrench.
TonyM
by TonyM
Yepp the lever works for front and rear.
I will not carry it as I have a multitool anyway with me.
Frankie - B
Administrator
by Frankie - B
LeDuke wrote:
A small dot of paint or a slight file mark on the TA help. As in, dot at 6 o’clock = properly tightened.
This is a great idea!
Please follow me on Instagram
