One thing I dislike with disc brakes
ODC
by ODC
I have an Tarmac sl6 with disk brakes (Dura Ace 9170).
There I already had the Shimano C40 disc wheels from my BMC SLR01 disc my shop installed these for me.
Now i bought a pair of Rovals clx50 at my shop without taking my bike with me. Installed the wheels on my bike and yes brake rub.
Is there always a minor adjustment to make to the brakes when changing wheelsets when not using the same hub?
Some tips to do it myself?
rheosibal
by rheosibal
Typically yes, minor adjustments are necessary. Were any of the old parts re-used? Or are you using new pads/rotors.
Instagram: joserheo
|| Mosaic RT-1 || Cannondale Evo || Cannondale CAAD10 ||
ODC
by ODC
rheosibal wrote:
Wed Jul 11, 2018 8:14 pm
Using my old pads but new rotors on the new wheels.
Is it also a good idea to change to new pads?
kdawg
by kdawg
Leonard Zinn did an article a few years ago about swapping wheels for cyclocross and you can space the rotors with washers to get them all the same.
I guess the conclusion from that is they are all usually differently spaced.
I find if I remove my wheel to put it in the car or something I have to fiddle about to get rid of some minor rub.
I'm left handed, if that matters.
CarlosFerreiro
by CarlosFerreiro
I've got 3 pairs of wheels matching. 2 pairs were close enough, one pair needed 3x0.2mm Syntace shims
LeMomo
by LeMomo
Sadly the spacing trick doesn’t work with centrelock rotors!
dcorn
by dcorn
I have two sets of wheels for cyclocross and don't get any rub when switching. They do use the same centerlock hub. No noise, no problems. I would think that all manufacturers would have the hub width and rotor mount in the exact same spot, or at least within one or two thousandths.
How often do you change disc wheels on a road bike anyway?
TonyM
by TonyM
ODC wrote:
Wed Jul 11, 2018 8:11 pm
The same applies also for a switch of rim brakes wheels as you sometimes have to realign the brake pads (and also sometimes switch the pads from aluminum to carbon or carbon Campy to Carbon Lightweight).
The best is that you learn how to do it indeed.
spdntrxi
by spdntrxi
dcorn wrote:
Wed Jul 11, 2018 9:05 pm
I have 4 sets rim brake wheelsets for Bike #1.. so if I get road disc I forsee atleast 2/3 wheelsets depending on conditions.
dvq
by dvq
TonyM wrote:
Wed Jul 11, 2018 9:10 pm
Same, I've never owned two sets of rim brake wheelsets that were perfectly dished exactly the same nor had the exact derailleur fine tuning needed. This is no different with disc. Adjust all your wheelsets to match or deal with adjusting everytime you switch.
ooo
by ooo
ODC, do they have the same rotor model?
My Shimano, Formula, Novatec centerlock hubs have the same rotor mount spacing,
centerlock hub + mtb centerlock rotor with big spider - same spacing #1
centerlock hub + mtb centerlock rotor without big spider - same spacing #2 (not equal to #1)
shimano 6-bolt hub + shimano 6-bolt rotor without big spider - same spacing as #2
centerlock hub + road centerlock rotor - no info about spacing
to fix spacing you can use shims. 6-bolts shims are cheap,
Centerlock specific shims ID 35.6 OD 38.9: youtube.com/watch?v=c4N58WYUWRQ
Also, some non specific catalog shims can be found in size 45mm OD 35mm ID
ms6073
by ms6073
LeMomo wrote:
Wed Jul 11, 2018 9:02 pm
Sadly the spacing trick doesn’t work with centerlock rotors!
Yes it does, it is just not as obvious where to source rotor shims for centerlock hubs. There was the 'Disc Frame / Multiple Wheelsets - Equalizing Rotor Spacing On All Wheels' thread not to long ago where the owner of November Cycles posted about offering shims for centerlock hubs but there was some backlash from non-US members balked at the shipping prices.
- Michael
LeDuke
by LeDuke
LeMomo wrote:Sadly the spacing trick doesn’t work with centrelock rotors!
False.
clm2206
by clm2206
Use Campagnolo wheels
Enviado desde mi SM-J700M mediante Tapatalk
JScycle
by JScycle
I can't remember where but I saw some centrelock microspacers
