Allez sprint disc
ancker
by ancker
rider1981 wrote:
Fri Sep 27, 2019 7:20 am
ancker wrote:
Mon May 06, 2019 5:42 pm
Finally my pic.
Allez Sprint Disc - 54cm
Reynolds AR58/62 Wheelset
- Dura Ace Rotors (160/140)
SRAM Red eTap HRD Groupset
- Power2Max NGeco Crank, Force22 Carbon Arms
- 53/39 SRAM Rings
3T Bars/Stem
Love your build. I think I saw earlier you'd switched form the rim brake version to the diac.? I have a Sagan edition Rim brake that I love but been toying with getting a disc frameset. How does the disc version compare ride wise? Also the geometry is a bit taller, is that noticeable? Cheers
I feel like the disc version is a bit stiffer, but I'm not able to provide anything beyond opinions.
I use this bike for <3 hour fast rides, and I have an S-Works Roubaix for anything where I think comfort might be preferred over speed.
I haven't noticed the slightly different geometry. I sometimes wish I would have gotten the 52, but that was the same with my rim brake bike too.
johnrho
by johnrho
So just picked up a 2020 Sagan Overexposed and planning to put Ultegra DI2. I noticed the two ports under the bottom bracket for the brake line and shift cable - is there any grommet that come with the frame? Especially for the the mechanical cable port since I’m using DI2. I didn’t see any that came with the frame.
cnynrpr
by cnynrpr
Does the frame come with any BB bearing dust cover?
icantaffordcycling
by icantaffordcycling
johnrho wrote:
Tue Oct 01, 2019 3:04 am
No
cnynrpr wrote:
Sun Oct 20, 2019 10:20 pm
It should come with the praxis snap rings and bearings. No dust cover as far as I know.
spdntrxi
by spdntrxi
dust covers usually come with the BB
HaroldC
by HaroldC
Just landed and will be builidng this up in the next few weeks.....
NoMütze
by NoMütze
happy to announce that i fished a trout!...
kroem
by kroem
:shock:
HaroldC
by HaroldC
@NoMutze - Nice catch! Here's a topcap you need to get for that frame:
https://www.maderad.com/shop/greenback
icantaffordcycling
NoMütze wrote:
Mon Feb 10, 2020 10:51 am
What size is that frame? :shock:
NoMütze
by NoMütze
size is 61...
HaroldC...that cap is sick...lol
Schadenfreude
by Schadenfreude
I’m hoping to get sizing advice on the Allez Sprint disc. I may have the chance to get a discounted size 52 frame. I’m approx 167cm/5’ 6” tall and inseam is 77cm/30”. I currently ride a Defy (size Small) using a shortish stem, either 80 or 90mm.
The reach is slightly longer on a 52 sprint, but the top tube length is almost the same. Stack is much lower though, almost 3cm.
A 49 seems to low at the front and I think the 54 would be too long and Standover height may be too tall. Has anyone else with a similar height and inseam gone with the 52?
johnrho
by johnrho
Schadenfreude wrote:I’m hoping to get sizing advice on the Allez Sprint disc. I may have the chance to get a discounted size 52 frame. I’m approx 167cm/5’ 6” tall and inseam is 77cm/30”. I currently ride a Defy (size Small) using a shortish stem, either 80 or 90mm.
I had to go down to a 49 with a 100mm stem because the reach was too long on the Allez Sprint. I ride a Wilier Cento10Air in a small as well with a 90mm stem and my fitter said the Allez Sprint in 52 would be too big. Also the amount of seatpost exposed wouldn’t be a lot less with the 52 vs a 49.
Schadenfreude
by Schadenfreude
Thanks for this. That’s interesting because I had a look at the geometry on the Willier and the reach and stack look roughly the same as the Sprint in a 52?
I’m not sure I could deal with the drop on a 49. The stack difference between a Small Defy and 49 is almost 4cm
Hexsense
by Hexsense
Don't adjust your position according to frame stack.
Adjust the set-up to fit your position instead.
Does the old bike have -17 degree stem? If so change to +6 degree stem bring it up by nearly 4cm with no spacer changed. But positive angle stem look a little wonky though. I'm 169cm and use 49. I'd happily use 52 too with steeper stem angle. On 49, I use -10 stem, if I use 52, I'd just use -17 degree stem. I wouldn't even change stem length because the reach difference between 49 and 52 is only 5mm.
Here are quick list of bar height related to stem angle (length=100mm)
Assuming -17 degree is the reference point:
-12 degree is 9mm taller
-10 degree is 12mm taller
-6 degree is 19mm taller (and 1mm shorter reach)
0 degree is 29mm taller (and 4mm shorter reach)
+6 degree is 39mm taller (and 8mm shorter reach)
source: http://yojimg.net/bike/web_tools/stem.php
