Forum rules
jlok
by jlok on Wed Jul 17, 2024 1:40 pm
toxin wrote: ↑Wed Jul 17, 2024 12:26 pm
They aren't making these hubs, they're from Nonplus
If youre talking about the IG post, then you're right.
But I am referring to this "The rim profile and LB's carbon spokes are the only questionmark for me".
The current LB carbon spoked wheels are relying on some unknown ODM hubs, which I am talking about. The quality is questionable.
Again, I wish LB can evolve into a true wheel mfg who also produce hubs, so that the wheel can be designed as a whole. Everything is optimized.
OtterSpace
by OtterSpace on Wed Jul 17, 2024 4:37 pm
mrlobber wrote: ↑Wed Jul 17, 2024 10:53 am
Interesting idea, but I, for instance, would always prioritize grip (and wet grip! where Contis never really shine) over aero or even RR in the mountains.
The reason I recommended trying Aero 111 is for the crosswind handling which is more linear and predictable at gusts of > +/- 10 degree yaw which isnt what they are primarily marketing towards but likely is the biggest advantage of the tire.
alanyu
by alanyu on Wed Jul 17, 2024 8:13 pm
OtterSpace wrote: ↑Wed Jul 17, 2024 4:37 pm
Exaxtly this. I posted the same opinion in the 111 thread in watt weenies forum.
jlok
by jlok on Thu Jul 18, 2024 1:23 am
toxin wrote: ↑Wed Jul 17, 2024 1:50 pm
Those are off the shelf Chosen hubs
I took another look and their spokes are 4.5/1.2 mm ellipses, so not the best but ok
The spokes themselves are fine so far, but the necessary hubs are not. I'd like to see DT / Shimano / Campy / WhiteInd / i9 all / some of these players to support the latest carbon spokes.
Jasonlelam
by Jasonlelam on Thu Jul 18, 2024 2:38 am
jlok wrote: ↑Wed Jul 17, 2024 1:40 pm
What strongly differentiate LB from other players IMO is their damn plenty of custom options. For carbon-spoke hubs, I think they are constantly seeking more reliable/decent partners (DT, I9 or NonPlus etc) to practically match the system optimization/custom demand.
jlok
by jlok on Thu Jul 18, 2024 3:00 am
Jasonlelam wrote: ↑Thu Jul 18, 2024 2:38 am
Yes, no doubt about the customization. And yes, they are constantly seeking more reliable partners, but the fact is that the carbon spokes dictate what hubs are usable
today. For the more reliable carbon spokes, only the dedicated slot-in style hubs are usable
today. That's all stem back to my first comment of "not recommend carbon spokes
today" due to the dedicated hubs quality are not quite there yet.
Again, I am not saying LB is bad and not to buy. I am waiting for LB to go further. I own AR45, WR50, AR565. Don't shoot
MichaelK
by MichaelK on Thu Jul 18, 2024 12:30 pm
I wouldn't recommend carbon spokes on slot-in hub based purely on the chances of catastrophic failure. I've seen some terrible accidents from one spoke snapping, causing all the rest to lose tension and simply fall out of the slots. Not the best design choice at all.
wheelbuilder
by wheelbuilder on Thu Jul 18, 2024 7:44 pm
MichaelK wrote:I wouldn't recommend carbon spokes on slot-in hub based purely on the chances of catastrophic failure. I've seen some terrible accidents from one spoke snapping, causing all the rest to lose tension and simply fall out of the slots. Not the best design choice at all.
Just watched a Peak Torque video?
RDY
by RDY on Thu Jul 18, 2024 9:11 pm
NonPlus do a dedicated hub for composite spokes - interesting take on high flange. One-K are using it, optimized for their spokes.
From what I've heard, you can buy the design suitable for use with the latest Stren or similar bladed carbon spokes. Just nobody has yet bitten (to my knowledge), presumably due to high cost.
MichaelK
by MichaelK on Thu Jul 18, 2024 11:13 pm
wheelbuilder wrote: ↑Thu Jul 18, 2024 7:44 pm
Nope, don't watch his videos (I pretty much only watch LR and Norcal on Youtube).
Gutonobre
by Gutonobre on Sat Jul 20, 2024 1:16 pm
Good morning, folks. I'm 1.89m and I'm 90 kilos. I have a 2015 Cervelo R5 with Enve 3.4 Gen1 wheels (DT Swiss 240S hubs). I'm thinking of upgrading to the Lightbycicle Falcon Pro AR465. My doubt is:
Is it better to reuse 240S hubs and buy only AR465 rims? If so, what is the ideal length of the spokes I will have to buy (I am thinking of the CX-Ray Sapim).
Or would I better buy an AR465 wheelset with CarbonTI hubs and leave the Enves as a reserve wheelset?
I intend to stay on the 25mm tyre (currently GP5000 brown)
Mr.Gib
by Mr.Gib on Sun Jul 21, 2024 5:46 am
Love my Carbon Ti hubs BUT at 90kg my advice is to avoid them. The alloy axles are soft and the inner bearing races, particularely the inboard bearing of the freehub, will cut into them. You will end up with noise that can only be solved with a new axle. I have had the problem at 75kg. The problem used to be worse when the axles were slightly undersized. Lately the axles are a snug fit so things are better but... DT Swiss for you IMO.
