Let's see your Swiss Machines // BMC
Moderators: maxim809, Moderator Team
MC356
by MC356
rainerhq wrote:
Sun Jun 02, 2019 7:21 pm
"not too bad" :D
I think its very bad, if chain falls off.
No shit it not good but the q-rings helped with my knee pain, small price to pay to keep riding.
BMC TMR01
Niner Air 9 RDO
mmendoza87
by mmendoza87
On the eve of BMC's new bike launches later this month which includes a new Roadmachine,
I took some new photos of my Roadmachine 02 with its new wheels and tires.
After 4,000km on this bike, I'm still quite happy with the RM. It's much heavier than my previous road bike, a 2015 Teammachine, but the versatility that comes from disc brakes and the big tire clearance makes it feel like a true all-rounder bike. Looking forward to put even bigger tires on it when I need a new set.
Sepeda
by Sepeda
Same frameset, different build :)
Frameset: BMC Roadmachine 02 2017 54
Groupset: Campagnolo Potenza Disc, 52/36 11-32
Wheelset: Unaas 40 Wide, 30 mm external/22 mm internal, 1450 grams
Tyres: Vittoria Corsa Graphene 2.0 TLR, 28 mm measuring 30 mm on these rims
Stem: BMC ICS
Handlebar: Syntace Racelight Carbon
Seat: Fizik Antares
Bottle cages: Arundel Mandible
Built for versatility and comfort, not low weight. Guess I'll weigh it at some point in time.
Photo taken at the harbour in Oslo, Norway.
kjetilEng
by kjetilEng
2019 BMC Teammachine SLR01 Disc One custom 51cm. 6.64 kg with pedals, cages and Garmin mount. deCADENse 38/49mm tubular wheels. DA di2 complete group and AB oval chainrings. Berk Lupina sadle.
addictR1
by addictR1
mmendoza87
by mmendoza87
Sepeda wrote:
Sun Jun 23, 2019 11:38 am
Stem: BMC ICS
Seat: Fizik Antares
Great build! Could you let me know if that is the ICS stem from the 01 model that fits directly on the 02 (round) steerer tube?
Sepeda
by Sepeda
mmendoza87 wrote:
Fri Jun 28, 2019 10:33 am
Thanks!
This is the ICS stem from 01, yes. It fits the round steerer tube of the 02, but you need the correct top cone for ICS in low or high version plus any spacers you may need. I use the low version and one spacer, which gives me a drop of about 10 cm from seat to bar. Both stem and cone are rather expensive, but I got the former second hand and the latter as surplus from my LBS.
Some 2019 RM02 came with the ICS stem originally, which is what gave me the idea. No integration, but I like the sleek look and the 12 degrees angle. I'm sure a similar set-up would look excellent on your nice build and match the high profile rims :thumbup:
But since we're on Weight Weenies: The ICS stem adds coolness, but also well over 100 grams as compared to a standard BMC stem, not to mention low weight alternatives :shock:
All of the above refers to Roadmachine 2017-19 and not the new 2020 :)
By the way, I'm quite please with Campagnolo, even though I chose the moderately priced Potenza. Wasn't able to find the caliper for 160 mm rotor in the back, so sadly had to use the less elegant adapter. Still, Roadmachine Potenza just sounds so nice.
NJCyclist
by NJCyclist
Here's my 2017 BMC Roadmachine RM01 in the Sunrise finish, with Ultegra di2.
I swapped out the wheels for Reynolds AR 58/62 DB, which I run tubeless with 28s. I've had tubeless Panaracer Gravel King 32s on there and they just cleared the stays.
Also swapped out the standard crankset for a Rotor 3D24 with a Power2Max NGEco powermeter and FSA Super rings (48/32).
Co-Founder SmrT Hydration
https://smrthydration.com/
https://www.facebook.com/smrthydration
#saddlebagssuck
bilwit
by bilwit
Had the bright idea to test the gravel capabilities of it this weekend on Tiger Mountain which is a gravel trail that goes up ~1000m and connects a lot of downhill MTB sections with pretty sketchy loose/chunky sections on its own (not pictured). I put latex tubes in to help prevent pinch flats (with great success) and put in a 32mm tire in the back (28mm in the front). It performed about as much as I expected.. uphill was doable and I was flying past all the MTB and proper gravel bike guys but downhill was a nightmare, was definitely beyond its limits at times especially with steep slushy corners.
Caught some cheeky "road bike, what are you doing here?" comments along the way :lol:
mmendoza87
by mmendoza87
Updated my RM02 with Di2 and a Black Inc barstem (see above for the before shots). Mechanical Ultegra R8020 shifted amazing but I wasn't a fan of the ergonomics, huge shifter body visual size, and sloppy rubber hood fit. It's like a whole different bike with this setup now and I love how the forms and proportions go together. I considered the BMC ICS stem but the Black Inc is nice because I can swap to another bike when the time comes.
riochang
by riochang
New bike day: BMC teammachine SLR01 disc with extralite cyberdisc 38c wheelset.
Bike weight excluding pedals 6.31kg
Sockman
by Sockman
2018 SLR01 frame, which I built up with 9100, Shimano DA powermeter, Ardennes+ wheelset and pro stealth LTD saddle. Probably going to switch it to di2 over winter. Not too sure of current weight, but somewhere around 7kg... Definitely have room to move in terms of weight, but I refuse to compromise ride quality and durability for a few grams here and there.
:thumbup:
iamraymond
by iamraymond
FYI for BMC SLR01 Disc owners:
https://www.cyclist.co.uk/news/7397/bmc ... disc-bikes
BMC stated it had 'identified a technical problem with the fork that could result in a cracked or broken steerer tube, leading to potential crashes and injuries.'
MY2018 and 2019 are affected
parajba
by parajba
With the latest Roadmachine models, which full mudguards can we use? Are they proprietary? What's the maximum tyre clearance with full mudguards? Am trying to pick my next winter bike...
bilwit
by bilwit
parajba wrote:
Wed Dec 18, 2019 12:17 am
None, only the first gen roadmachines 02/03 support full fenders. The new ones only have a stupid bolt on the seatpost that supports a proprietary ass-saver. The old ones can only fit 28mm with full fenders, only 32mm without.
