MTB for flat gravel. Gearing problems.
TonyM
by TonyM
Hi,
I am using my MTB for flat gravel currently and I see that I am only using the 42x13 to 42x15. I will ultimately have to replace my chain and cassettes more often and I actually would like to have a better gearing now.
The bike has an XTR crankset (FC-M980, Hollowtech 2, 42x32x24) and the cassette is a XT 11-32.
Is there any way to get a more adequate gearing for flat gravel?
I didn’t see any XTR chainring above 42 for example.
Or should I switch to XTR M980 double chainset with a chainring bigger than 44 or 46 for example? Can I then keep my current left crank with Stages PM?
What do you think?
Any ideas?
mattr
by mattr
TBH, whatever you do is going to cause issues, you're using such a narrow range of gears. Bigger ring will just mean you wear out the two or three sprockets further up the cassette.
One solution might be a single large (cx sized) chain ring and a road cassette.
It's a big old gear though, what's your cadence like?
TonyM
by TonyM
I ride currently on flat gravel so around 90rpm like in the road bike.
jemima
by jemima
Curve Grovel ti.
TonyM
by TonyM
Thanks!
The idea with the road cassette is interesting as I could find some CS-6700 Ultegra 11-23 and 12-23 that at least give me more gears between 25km/h and 35 km/h. And together with a 44T that should be fine I think.
The cleanest route would be to change my 3x to a 2x system. I would need to swap the crankset (3x to 2x) and the front derailleur and I could keep my Stages powermeter and the front shifter that operate 3x and 2x as I just learned.
Marin
by Marin
Why not go 1x and use a road cassette? There's tons of 1x chainrings out there (but get a Wolftooth if there is one) and you can ditch the left shifter, front der & cables.
mattr
by mattr
mattr wrote:
Wed Jun 20, 2018 9:18 pm
:wink:
Also, have a play with http://www.gear-calculator.com/# and see whats going on.
TonyM
by TonyM
Marin wrote:
Thu Jun 21, 2018 7:46 am
I would like to keep my left XTR crank with the Stages powermeter.
XTR M980/985 etc.. doesn't have any 1x crankset.
Or do you mean that I can mount a single chainring on my 3x crankset and use it as 1x?
mattr
by mattr
Yes.
Marin
by Marin
TonyM wrote:
Thu Jun 21, 2018 4:07 pm
Exactly
TonyM
by TonyM
Short feedback:
I went for the cheapest option first and installed a road 12-23 cassette together with my 22-32-44 crankset. It works actually great as I have now more option for flat terrain. My FD however did not work well with the smallest chainring and the 12-23 (compared to the 11-34 that I had before). I am going to have a look at it now.
