BMC TimeMachine Road 2019
spdntrxi
by spdntrxi
somewhat surprised at frame weight... it's over 1kg @ 1042g... Fork is portly as well, but it's not cut yet @ 475g . Frame was weighed with hanger some rubber covers for Di2 most likely the seatpost binder weighs a ton. Still I dont see how a 54 is going to weigh 980g with all this stuff removed when mine is a 47. Stem is 220g (100mm) Seatpost is 193g which is not bad... but it's really short. Just tall enough for me so its ok. Atleast the thur axles end up light..at 54g for the pair. My 40cm bars are 233g.
I will get around to a build post eventually...
better be fast... frame / fork is heavier then my gravel bike :noidea:
addictR1
by addictR1
Yup.. seems like the new timemachine is very porky. GCN weighed Dimension Data’s bike and one was like 7.8Kg
spdntrxi
by spdntrxi
addictR1 wrote:
Tue Mar 12, 2019 6:43 am
Yup.. seems like the new timemachine is very porky. GCN weighed Dimension Data’s bike and one was like 7.8Kg Image
my goal is 7.5ish.. honestly I dont know anymore :noidea: The video I watched it was 7.61kg which gave me hope.
ryanw
by ryanw
7.85kg on tubs... but with Garmin and transponder.
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
spdntrxi
by spdntrxi
what video are you guys watching that I missed ? I watched Ryan Gibbons bike weigh in.. 7.61kg. 7:01 on the clock (no deep wheels)
AlgaeHater
by AlgaeHater
One thing I don't understand is why after all of the weight saving measures designing the TM, BMC elects to use such heavy saddle mounting hardware. The clamp hardware is super chunky compared to my RoadMachine and the main mounting bolt is huge! The setup is far heavier than what I've seen on other aero bikes (e.g Venge). To make matters worse, adjusting the saddle angle/fore/aft is a major PITA. Just a bad design overall IMO.
2019 Bianchi Oltre XR4 eTap
2019 BMC Timemachine Road 01 Di2
2018 BMC Roadmachine 02 Di2
spdntrxi
by spdntrxi
AlgaeHater wrote:
Tue Mar 12, 2019 5:45 pm
yeah coming from a TimeMachine TT rig... very used to the clunkiness and large bolt. Adjusting for me is easy peasy...plenty of practice on the tri-rig. I will be looking into some weight saving parts.. still want a goal of 7.5kg.
AlgaeHater
by AlgaeHater
spdntrxi wrote:
Tue Mar 12, 2019 5:53 pm
That's exactly my issue. I can understand why heavy saddle mount hardware wouldn't be much of an issue on a TT bike where aero > weight, but why would BMC re-use this on an road bike. A bit disappointing for an otherwise innovative design.
spdntrxi
by spdntrxi
I think this bike is still putting aero>weight
spdntrxi
by spdntrxi
FYI.. the seat clamping paper weight weighs in @ 74g. The bolt alone is 17g :noidea:
addictR1
by addictR1
AlgaeHater wrote:One thing I don't understand is why after all of the weight saving measures designing the TM, BMC elects to use such heavy saddle mounting hardware. The clamp hardware is super chunky compared to my RoadMachine and the main mounting bolt is huge! The setup is far heavier than what I've seen on other aero bikes (e.g Venge). To make matters worse, adjusting the saddle angle/fore/aft is a major PITA. Just a bad design overall IMO.
I agree.. I have a 17 TMR 02 and the seatpost clamp is a big chunk of metal. :(
Thought about getting the one piece seatpost plus saddle from DASH to save weight but $1K kills the deal.
Ettore
by Ettore
spdntrxi wrote:
Tue Mar 12, 2019 6:04 pm
I think so too. It can be lighter, but it'll be less aero and less stiff when sprinting for the line.
Philbar72
by Philbar72
its a throwback to the original timemachine. this design gives you a ton of flexibility, though you are right the hardware is not light. the design is great for me, but as you say could be lighter. that bolt :D :D :D :D
AlgaeHater
by AlgaeHater
Philbar72 wrote:
Wed Mar 13, 2019 1:56 pm
Yes that is certainly an upside. It's a super aero post with three different mounting points to really get your setback dialed in. The mount is very reliable and rigid once set.
dorin
by dorin
I’m looking for aerobars solution, they’re super comfortable on long rides, looking at the METRON 4D FLAT M.A.S, it has integrated support for clip on.
NOW in order to keep all neat I’d like to keep the integrated option. One alternative would be to get the ICS Stem, instead of the aero one but the braking cables will be visible near the stem area.
I googled and I find mixed opinions, some even here on weightweenies, but does anyone has any experience with drilling a hole at the clamping area (diameter 1cm) that would allow the internal routing into the stem?
The metron 4d is strong enough allowing for clip on, the drill will not have corners (important for structural resistance), in theory should be fine but the idea freaks me out, anyone with experience on this or is it a hands down a dumb way to go?
Cheers.
