Cervelo s5 Pressfit
Cyppen
by Cyppen
Just bought a cervelo s5 with bbright.
I have a DA SRM so i Got a net BB Press fit bearing.
Everytime i riding the Pressfit cup losing from the Frame in the drive side.
Should i use locktite?
Or get a new pressfit bearing?
wingguy
by wingguy
Yes you should be using locktite. I would also check you've put the crank together properly. Correct me if I'm wrong but while an imperfectly fitted PF bearing will creak, the preload from the crank shouldn't permit it to migrate loose in the frame no matter how poor the bearing fit is :noidea:
kode54
by kode54
use the Loctite 609.. its red.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
1415chris
by 1415chris
You would also need a primer 7649.
But honestly I would scrap these plastic cups and replace them with aluminium screwed-together bottom bracket.
hambini
by hambini
I would use 7649 and medium strength 641 retaining compound.
Some of the red loctites (number not specified) will trash the carbon.
I've got an S5 and I found there was quite a bit of misalignment between the left and right sides which caused the creaking.
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
Geoff
by Geoff
I am running a similar set-up. I have not been able to solve that issue with a solution that lasts. I am thinking of going to a threaded BB solution now.
1415chris
by 1415chris
hambini wrote:I would use 7649 and medium strength 641 retaining compound.
This is what I was suspecting with my S5 when after short period of time two bearings (oryginal Rotor and Enduro replacement) on NDS started grinding.
After swaping plastic cups for aluminium threaded-together bb (Wheels mfg) similar thing happened with Enduro angular bearing, this time on DS :)
I gave up on Enduro bearings, went for NTN LLB ultra low friction seal bearings (from hambini). So far so good.
Having said all that, for number of years I didn't have any issues using plastic Sram bb-right bb on R5.
