Campy SRM vs P2M on BB area!
avispa
by avispa
I need your assistance if you have/have had and Campy SRM and Power 2 Max Power Meters... I got a hold of a 4-bolt campagnolo 54X42 rings, and installed them on my SRM power meter. I found out that the combination of frame use (a Pinarello F8) and the SRM Power Meter is not a good mix. Any inner ring larger than 40T will rub against the drive side chain stay. I tested this setup on my older Pinarello 65.1 and there is plenty of clearance... The F8 seems to have been built way to tight in the BB/Chain stay area. Although, I am aware that the SRM Campy Power Meters can be a problem because the warp around the BB cups a lot!
Thanks!
