Yes it will work.AG51 wrote: ↑Wed May 15, 2024 1:56 pmOk thanks for the info, at this time I have: oe headset cap,5mm spacer and transition spacer for the -12 stem, I believe the EXS kit might work.wziel wrote: ↑Tue May 14, 2024 10:21 pmit doesn't sit flash because I don't use the exs transition spacer. The fork steerer tube was cut to a minimum for the OEM stem by the previous owner. The stack on the exs is a bit higher than the OEM, so I decided to "gain" some of the steerer tube by removing the transition spacer. TBH I like a lower position, so this worked for me.AG51 wrote: ↑Tue May 14, 2024 6:05 pm
Very nice build, I do own a venge as well and was thinking on switching the oe stem/bar combo to EXS Aerover, on yours I do see somekind of spacer between the handlebar and the headset topcap that doesn't sit flush, can you elaborate on that pls, is that the spacer (transition) that exs provide for the venge or something you put yourself?
regards
S-Works Venge 2019
Inviato dal mio iPhone utilizzando Tapatalk
Also the chain rings but I just wanted to stay under 7
But..
Is there a one piece bar that match the spacers flawlessly?
But..
Roval rapide cockpit with these spacers from Magcad: https://www.magcad-designs.com/products ... 2234&_ss=rrobertonavaz wrote: ↑Sat Jun 22, 2024 9:21 amAlso the chain rings but I just wanted to stay under 7
But..
I used the sub-300g RSL VRC with the spacer for standard stems and it looked clean.robertonavaz wrote: ↑Sat Jun 22, 2024 9:21 amAlso the chain rings but I just wanted to stay under 7
But..
Impressive weight, I may have missed it but what are the components to get you under 7kg?
Not sure how, but my front derailleur mount has a dent in it and the chain is catching. It's not a serviceable part because it's riveted to the frame. I registered the bike 4 years ago and I know the frame has a lifetime warranty, I can see this is included with a new frame - do you think this will be included? Specialized have offered me a discount off a new frameset but they haven't said how much yet...
I've checked my local specialized store and contacted specialized and no one has offered me a part number or option.
I was hoping the fault might be considered part of the frame lifetime warranty as it's riveted on and also sold as part of the frameset. However, Specialized have said that the mech has moved causing the mounting tab to warp rather than a manufacturing defect with the frame. They are offering an assisted purchase off a new frame. Not sure if I have a case to push for the frame warranty.
Get someone to CNC you a new mount, might be the cheapest solution.xylar wrote: ↑Fri Aug 16, 2024 9:11 amI've checked my local specialized store and contacted specialized and no one has offered me a part number or option.
Hi can someone tell me if there’s an integrated cockpit less expensive than roval rapide but in the same weight range?
Possibly something that fits clean with spacers like the magcad ones?
