My new Tarmac S-works
poppiholla
by poppiholla
Finally in the house. My Tarmac S-works SL6
Frame: Specialized Tarmac S-works SL6 Cameleon Green (size 58)
Shifting: Sram Red Etap
Crankset: Sram Red Quark Dzero 175mm
Cassette: Sram Force 11-28
Chain: Sram Red
Wheels: Fulcrum Speed 55C
Saddle: Fizik Antares R1
Handlebar: Specialized S-works 44cm
Stem: S-works SL 11cm
Bottle cages: Tune Wassertrager
Brakes: Shimano Ultegra Direct Mount (when available replace by Sram S-900 direct mount)
Seatpost: S-works
Tires: Schwalbe One 25mm + Conti 80mm binnenbanden
Garmin: Edge 1030 + Garmin out front mount
Pedals: Look Keo Blade 2 (20nm)
Handlebar tape: S-works cork
Weight all in: 7.2kg
Setup will probably change a little bit. Stem is correct height, but I have to check first. Decals on Fulcrum wheels are waterslide decals. Very thin. Probably removable with Microscale Microsol if the decals are not beneath clear coat. I need confirmation about this. I like the grey decals on the wheels but the red ones are probably a little bit too big. I will also check the weight of the bike with my Lightweight Meilenstein C wheelset. I will make pictures. Tomorrow I will test the bike. ;-)
Ciao
happyon2wheels
by happyon2wheels
What a spectacular paintjob. I never knew it was so lustrous but your pics certainly captured this excellently.
Great looking bike!
poppiholla
by poppiholla
Thanks! The paint plays in the sun. The ride on this Tarmac is also great.
rexyi1990
by rexyi1990
Most beautiful Sworks I have ever seen...
bencolem
by bencolem
Great color scheme - but I’d go for some plain (matte UD carbon) wheels with no decals aesthetically - the fulcrum’s are quite loud. That frame should be allowed to do all the talking on its own!
poppiholla
by poppiholla
Thanks all. Here a few pictures of the frame with my Lightweight Meilenstein Clinchers.
The all in weight is now around the 6.8kg. This can be a little lower with Sram Red cassette and lighter tires. EE brakes would be another option but I prefer the SraM Red S900 direct mount brakes when they are available (here in the Netherlands).
sychen
by sychen
Damn that's a nice colour.. Looks great with the LW wheels.
KCookie
by KCookie
Looks so much better with the Lightweights on, plus a 400g saving. Awesome.
