Specialized Allez Custom 6.5kg
dannyperish
by dannyperish
Hello!
I am not live in mountains, so I build x1 race setup on Specialized Allez Comp 2015 frame 49cm (top of line).
It feels stiff, very light and fast.
Complete weight is 6.550 grams with pedals, and it can be go down by wheels, saddle and rear derailleur (road version) to under 6kg easy, but I like current.
Frame weight is ~1000grams without painting (Specialized paint is so good and fat, its near 200 grams goes down after cleaning frame), fork is standard 360grams without paint
Details:
Frame Spesh Allez - 1000g
Fork Spesh full carbon - 360g
Headset Spesh - ~100g
seatpost clamp Carbonice Eva 2.0 Carbon - 12g?
Seatpost Easton EC90 cuted - 140g
Seat Selle Italia SLR SuperFlow - 180g
Stem Deda Superleggero 100mm - 100g
Bar 3T Aeronova LTD 40cm - 200g
Bartape Fizik - 40g?
bottle cage - 36g cleaned
Cables Jagwire Elite 120g?
Brakes Sram Red - 260g
Rear derailleur Force1 2.1 - 260g
Crankset Sram Red - 350g
Bottom Bracket BB30 - 60g
Chainrings Sram Force1 50t - 120g?
Chain KCNC - 220g
Shifters Sram Force1 - 270g
Cassette Sram Red 11-28t - 190g
Wheels Vittoria Qurano 46 clincher - 1550g
Tires Continental GP4000II - 460g
Pedals Shimano Ultegra - 260g
And some accessories
Mcfk Expander
Tune Carbon UD Ahead Cap
Tune Skyline Road Quick Release
Corima Pads
pedalroom.com/bike/specialized-allez-custom-37015
sib
by sib
That looks amazing..!!
spdntrxi
by spdntrxi
that's a 49
CrankAddictsRich
by CrankAddictsRich
spdntrxi wrote:
Mon May 07, 2018 2:13 am
that's a 49
Yes... that would be my guess. I was just looking for confirmation. That also explains the weight difference between this bare frame and mine.
happyon2wheels
by happyon2wheels
Great looking Allez.
I am the happy owner of a (Keyline color) Allez E5 SW frame and have considered for some time to strip the paint and if the stated reduction of 200g just from the paint is real, this could definitely sway me towards going naked...figuratively speaking, of course.
Also, your frame seems to have a really nice sheen (where Richs' looks more like brushed aluminium), what did you use to strip the paint?
CrankAddictsRich
by CrankAddictsRich
I actually think the finishes look pretty similar.... but it really just all coes down to how much work you want to do after the stripping process. I wanted a brushed look, so I spent a few days using some steel wool to get that look. If you wanted it really shiny, you could easily spend a little moe time with a polishing wheel and compound and make it look almost like chrome.
spdntrxi
by spdntrxi
brushed look is good.. I like it
dannyperish
by dannyperish
Great looking bike and build... what size is the frame?
49cm, yes
the same frame as yours
with black parts of headset naked frame weights 1060gr (I didn't remove it)
and yes, I was inspired by your bike ^^
your Allez absolutely stunning as custom setup of road bike
first I used the paint remover
3 times, it took 2-3 hours
then I used sandpaper to polish and clean the remains of the soil, it took several days
polishing with steel wool took only 1 day, its not perfect at all
I didn't use varnish, after polishing, it's raw alu
but the hardest part was with the carbo fork, because I could not use paint remover
cleaning the fork took a few hard days
I used sandpaper from 200 to 1000, then covered with two coats of varnish (down from 382gr to 360, not the best weight for fork)
I will never try to do it again, but the result is completely satisfied me
The frame is really stiff, light and comfortable enough like good carbon frames.
CrankAddictsRich
by CrankAddictsRich
Thanks man... cool to hear that you were inspored by my build. You did an equally great job. The final build is light.
My frame, bare was 1115g, but it's a size 54 so there's some extra weight there. It went up to 1166 with the S-Works decals and clear coat and the original frame weight was 1250g. I upgraded to an S-Works Tarmac fork and that dropped the fork weight from 391g (cut) to 300g (cut). both forks were cut to same length.
I absolutely love riding mine... I love riding my Venge too, but there's something different and satisfying about the Allez.
