Cassette lockring tool question
CallumRD1
by CallumRD1
I'm looking for a quality cassette lockring tool that has a 3/8" or 1/2" square drive on it so that I can use a ratchet or torque wrench for installation and removal. Does anyone know of one that offers that? It appears that the park tool cassette lockring tool doesn't and can only be used with an open end wrench.
Orlok
by Orlok
CallumRD1 wrote:
Fri May 04, 2018 3:42 pm
Take a visit to your locale bike shop, they will have it! :wink:
Once comes a time that you'll have a tailwind :D
Pinarello F10 - Ultegra 6800 - Carbonspeed C38 - Tubeless
kode54
by kode54
depends if Shimano or Campy. the Shimano branded one has a 1/2" drive for wrenches.
i use the Abbey Tools Crombie that has Campy on one side and Shimano on the other. one of my best tools.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
ManekiNico
by ManekiNico
Or try a socket (or crows foot wrench). Depending on your torque wrench, you may also need an adapter.
Park Tool BBT-5/FR-11, 1” socket, 3/8” to 1/2” adapter:
+1 Crombie tool
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
dmp
by dmp
I use what Manekinico suggested, but of course you will need a chain whip, too.
RussellS
by RussellS
Appears to be confusion here. As in CallumRD1 the author does not know how wrenches or sockets work. Go with what ManekiNico says. Both the Park Shimano and Campagnolo lockring tools fit into a 1" socket. Put the 1" socket onto your 3/8" or 1/2" ratchet torque wrench.
kdawg
by kdawg
I recently bought this one - good value and would fit a socket or fits my torque wrench directly (1/2” hole I think).
https://www.amazon.co.uk/IceToolz-Casse ... B0028N57UU
I'm left handed, if that matters.
CallumRD1
by CallumRD1
RussellS wrote:
Fri May 04, 2018 9:36 pm
There is no confusion here; I know exactly how wrenches and sockets work. (I'm halfway through building a Pitts S-1S biplane at the moment so I definitely know my way around a workshop!) I am looking for a cassette lockring tool that has a square drive recess in it so that I can attach it to a wrench directly. As suggested above, I could use a 1" socket on the park lockring tool, but that wasn't the solution I was looking for. It is a good suggestion, though. Functionally the two solutions are very similar, but in my opinion the single tool is superior, hence why I was looking for one.
CallumRD1
by CallumRD1
kdawg wrote:
Fri May 04, 2018 9:49 pm
Thanks for the suggestion. I'll look into that model.
Valbrona
by Valbrona
Cyclus do 3/8" tools in both Campag and Shim/RAM patterns.
1/ Only use them for fitting lockrings. They don't offer really good purchase.
2/ Use with a beam or electronic torque wrench as the clicker-type ones do not work well with serrated lockrings.
Putting a tool into a socket and then putting the socket onto a torque wrench is for [removed - please keep this PG]
Frankie - B
Administrator
by Frankie - B
This topic raises my eyebrows a bit. I have never used a torque wrench on a cassette lockring, just a crombie. My cassette lockrings are always secured by feel and i have never had one come off.
I’m sure it is pretty cool to have everything torqued to spec, but in this case i don’t see the need.
Please follow me on Instagram
Attermann
by Attermann
Frankie - B wrote:
Sat May 05, 2018 6:36 am
Shimano doesn’t mind, the way the 11 is designed, but Campagnolo, you can compress it too much
ipaul
by ipaul
https://www.abbeybiketools.com/collecti ... et-crombie
Not cheap but with such specific requirements most things are not.
:P
F45
by F45
Had the same desire, but what I did was tack weld a cheap adjustable wrench to my cheap cassette lockring tool. For torque I put my hook scale in the hole at the end of the and pull to a pre determined value.
ManekiNico
by ManekiNico
@CallumRD1, never presumed that you might not "know how wrenches or sockets work," just thought you might have overlooked a possible solution. Lord knows I do it all the time. Sorry for not answering your question.
You won't get an argument from me that a direct wrench/tool connection will always be better than wrench/socket/tool. I'll admit my own setup is a little wobbly what with tolerances being on the loose side.
And yeah, @Frankie - B, torquing the lockring is probably overkill. It's more a question of "Well, since I'm already torquing stuff down…"
Clearly, I need to rethink my way of doing things as it seems it's not only unnecessary but it also impugns my manhood… :?
