Bora WTO
fogman
by fogman
On my WTO 33, when I mount my front wheel so that the AC3 grooves are aligned the same as the rear wheel, my bearing preload adjuster ends up being on the NDS.
There is another member who has the front wheel backwards from this (bearing preload adjuster is on the drive side when AC3 grooves aligned with rear wheel).
Can any other WTO owners confirm which side your front preload adjuster is on when the AC3 grooves are aligned? Does it even matter?
I have four sets of Campagnolo wheels (Shamal Ultra, Bora One 35 Clincher, Bora One 50 Tubular, and Bora WTO 33). On all four sets, the front bearing preload adjuster is on the left NDS.
It's all downhill from here, except for the uphills.
pdlpsher1
by pdlpsher1
I have non-AC3 Bora wheels and my adjuster is on the NDS. On my wheels there are words on the hub shells. When the front adjuster is on the NDS the words match the same orientation as on the rear wheel. You got your right since the AC3 grooves match between the front and rear wheels. In real life I doubt it matters.
Vuong05
by Vuong05
On my WTO 60 wheelset, the front bearing preload adjuster is on the left NDS.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg)
jeanjacques
by jeanjacques
I have a lot of black dust on the caliper with my WTO, the noise is also pretty loud, only 200km with it but very hilly:
Normal ?
smz5969
by smz5969
Hi all,
Just got my 45’s last Friday. Can’t wait to get it rolling! Image
Nohands83
by Nohands83
jeanjacques wrote:
Sat Jun 27, 2020 3:10 pm
Normal ?
Same here, nothing to worry about - just the pads and rims bedding in. The pads seem to have a black layer above the red main body so probably that wearing through.
jeanjacques
by jeanjacques
Thank you :wink:
nismosr
by nismosr
Got another set but disc and they are xdr hub! Any one here know how to remove the xdr freehub body wanted to replace them with campagnolo.
Colnago C64 Mapei - Campagnolo SR11 EPS - Campagnolo Bora WTO 60 - P2Max
3T Strada Due - Sram Force AXS Etap
Basso Diamante - Campagnolo SR11 EPS - Lightweight Meilenstein - P2Max
jlok
by jlok
nismosr wrote:
Thu Jul 02, 2020 3:42 am
https://www.campagnolo.com/media/files/ ... 19_ENG.pdf
Follow the instructions for Zonda DB in Page 4. I did it to my Bora WTO 45 DB.
nismosr
by nismosr
jlok wrote:
Thu Jul 02, 2020 8:45 am
Did you have to buy that special tooL ? thank you
jlok
by jlok
No I didn't. One adjustable spanner and one 17mm are what I use.
p.s. Racing Zero Carbon DB came with that special tool but not in Speed 55 DB... strange.
maxim809
by maxim809
Just got 60mm WTOs which I plan to run tubeless (first time tubeless, EEK)
Huge mental struggle between 45 vs 60. Thought about asking the various cycling forums for help, but knowing how these 'dilemma' questions can go, I internalized the mental debate and went for the deeper dish. I'm 140lbs/63.5kg and I get tossed around like crazy in winds over +16mph, even with 35mm rims. I have prior experience with deep dish though, so we shall see. Fingers crossed I didn't make a mistake not going 45's, but only one way to find out!
Need to wait a week to install, the package didn't come with 2x tubeless valves and I'm sorting that out with the vendor.
SOME WEIGHTS
Front Wheel: 714g
Rear Wheel w/ Campy Freehub: 900g
QR Skewers (x2): 120g
Red Brakepads (x4): 15g
Like mentioned earlier, no tubeless valves to weigh. The wheel set themselves are 1614g, and the total with skewers/pads is 1749g before sealant/tires. Campy's website claims the rim/spoke wheel set weighs 1547g. Kinda close. My measurement's got the freehub body attached.
2013 Cannondale Synapse | 2015 LaPierre Pulsium | 2016 Pinarello Dogma F8 | 2016 Bianchi XR4 | 2019 Spesh Sprint
zappafile123
by zappafile123
maxim809 wrote:
Tue Jul 07, 2020 8:02 pm
SOME WEIGHTS
Front Wheel: 714g
Thanks for the weights! You made the right choice as for depth. 45 mm wheels are a waste of time, 50-90 mm is where its at ;) I'm the same weight as you and ride around on knight 95s atm and have no issue with wind. The moral of the story is that yes, deep wheels get pushed around, but *you get used to it* so its no longer scary. Put them on, ride and keep going. Be sure to write a ride report.
Enigma Elite HSS|Sworks SL6|Colnago C60|De Rosa Protos|Bianchi Oltre XR4/2|BMC SLR01 16|Cdale Evo HM 12|Focus Izalco Max|RidleyHelium SL/SLX|BH Ultralight|Basso Diamante 15|Scapin Dyseys S8|Time ZXRS|TCR SL 12|Ridley Noah 08|Look 585|Cervelo SLC
hkgmatt
by hkgmatt
I just recently got my WTO 60 DB and my initial impression is that they feel harsher, and when accelerating less agile, than my 47mm DT Swiss ERC 1100. I'm guessing the harsher feeling is due to the additional stiffness from the wheel depth, although these are my first 60mm wheels so I don't have anything to compare. They roll beautifully though so no regrets.
nismosr
by nismosr
fogman wrote:
Tue Jun 23, 2020 4:49 am
@fogman
so i emailed Campagnolo about the wrong lacing on my wto 60 front wheel and If I go against the grooves here's their respond
ImageWto by nismosr, on Flickr
