Homemade Di2 sprint/climbing shifters
TheDoctor
by TheDoctor
In its normal "unhacked" setup, pushing one of the buttons down will close the circuit by connecting the inner and outer part of the contact. One of the buttons shifts up, the other one down. In this hack what you're essentially doing is to move the button that makes the contact to somewhere else (and replace it with a small microswitch). So what you need for each of the two contacts, is a wire core going from the outer part of the contact to a pole of the microswitch, and a core from the other pole of the microswitch to the centre part of the contact.
Pushing the microswitch will then close the circuit and perform a switch (either up or down). Same for the other contact of course.
So I have one length of two-core wire for each of the two microswitches. Of each wire, one core is soldered to the centre of the contact, and one to the outside. On the other end, one core to each pole of the microswitch.
Hope this clarifies?
Scott Addict Premium Disc
Argon 18 Nitrogen
Specialized Tarmac SL4 Pro
Canyon Exceed CF SLX 8.0
thefuzzycow
by thefuzzycow
TheDoctor wrote:
Mon Sep 17, 2018 4:53 pm
100% on the nose! I’ll show you when done!!
"moo"
3T Exploro
Specialized CruX
Pivot Trail 429
Cw75lea
by Cw75lea
IrrelevantD wrote:
Mon Aug 20, 2018 6:59 pm
So the sprint shifters are just that, momentary button that just complets a circuit. HOWEVER, the sprint shifters can only work if plugged into compatible brake levers (9070, 6870 and 9150), they only serve one function and are not programable. The left button moves the RD left (bigger), the right button moves it right (smaller). The climbing switches used here can operate completely independent of brake levers and have the same programability. They are essentially the same as the two buttons on the levers, so you could use them with non-Shimano brake-only levers. Ive seen people do this with flat bar conversions and non-shimano hydraulic levers.
EDIT: I just read up a few posts and saw your mention of having 8050. Completely disregard everything I've said about cutting e-tube cables and making the sprint shifters because they won't work with the 8050. It only works with SW-R610 compatible levers.
Why do you say this won't work with the 8050's? The 8050's have a dedicated sprint shift or "dumb" switch port. I was thinking I would make my own shifters using cut etubes with 2 tactile switches on the left side of the bar (1 sprint button position and 1 near the stem as a climber) for down shifting the rear and, 2 tactile switches on the right side of the bar (1 sprint button position and 1 near the stem as a climber) for upshifting the rear. I don't care to have a button in either position to switch the front derailleur as most of the terrain I have I'm either 100% in the big ring or 100% in the small. As well if running synchronized shifting the front wouldn't be done manually anyway.
Carter
Cw75lea
by Cw75lea
CallumRD1 wrote:
Mon Apr 23, 2018 4:58 pm
The switches were installed with a dab of hot glue and the circuit board and wiring were hidden under the bar tape. It all appears to be working perfectly, the only (non) issue being that I had neglected to remember which switch was up and which was down before soldering, so I had the left and right hand switches backwards (i.e. left hand switches move the rear derailleur to a harder gear and vice versa). This was easily rectified in the etube app by switching the roles of the buttons. All told this implementation took about an hour at a desk and 15 minutes to install.
Edit: fixed typo
So the switches shown in both of these images you just hot glued directly to the bar and then wrapped over them?
CallumRD1
by CallumRD1
Exactly. The hot glue works best if you put a small piece of hockey tape on the bar first. The glue sticks really well to the tape but not so well to the carbon bar itself.
Cw75lea
by Cw75lea
Awesome, thank you.
IrrelevantD
by IrrelevantD
Cw75lea wrote:
Wed Nov 14, 2018 11:48 pm
Carter
late response, I've been traveling for work and haven't been watching the forums.
I had read somewhere that the new 8050 and 9150's got rid of the dumb port and that the old sprint buttons no longer worked on the newer generation brifters. If this is incorrect and it actually works, please let me know. I've been thinking about getting a pair of 8050s for my road bike and picking up some used parts to upgrade my CX bike to Di2 and using the 6870s there.
Goldenbear
by Goldenbear
IrrelevantD wrote:
Fri Nov 23, 2018 4:56 pm
Carter
Confirmed. Lowest port on each shifter is keyed for the sprint shifter. Just completed my first build yesterday. Here’s some pics of each shifter housing before cleaning up.
kode54
by kode54
Looks like you're using the middle port? The lowest bottom port still has the dummy plug in it.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
ms6073
by ms6073
Since the plugs are fully seated, it would appears the previous poster has a bar end junction with the Y-cable, not sprint shifters, which would not be able to be fully inserted into a non-keyed port.
JeffK
by JeffK
Has anyone tried splicing into the button that is under the hood on the new hydraulic shifters? I bet it is a dumb button just like the older sprint shifters and if a button or the older sprint shifters were spliced in parallel it would work just the same way. See picture.
zvucetic
by zvucetic
JeffK wrote:
Sun Mar 24, 2019 4:35 pm
Did you try this, it's interesting option for me as well :)
1sanglier
by 1sanglier
You can configure it with eTube software. Shifting option
Or by computer if you have the ew-wu111, Page change option
tomtom
by tomtom
1sanglier wrote:
Thu May 02, 2019 12:55 pm
So it's not "dumb" you say?
Canyon CF SLX Di2 2018
Canyon Aeroad CF SL Di2 Disc 2017
Canyon Speedmax CF Ultegra Di2 2015
davidodem
by davidodem
This thread is exactly what I was looking for!!
I have the latest DA R9150, I'm looking to add climber and sprinter buttons.
First off will the SW-R600 work with the hydraulic R9150? I do have one open dummy port on the left shifter, is this where I would connect it?
Are these the right buttons? liking the smallest ones on this set. 6x6x5 or 6x6x4.3. Looking for the absolute lowest profile buttons.
https://www.amazon.com/OCR-Tactile-Butt ... way&sr=8-4
