Having a rough week (C60 crack)
Bigger Gear
by Bigger Gear
I am certainly not having the best week with bike related issues. I had already posted about a leaky DA 9120 hydro STI lever that is looking like a warranty item. Then I found this crack at the brake cable exit on my C60! Aargh.
Frame was bought from Wrenchscience in late 2014. It actually has quite low hours on it, for a variety of reasons (health-related, PNW weather-related, etc). The warranty period is 3 years so I am outside that time frame, but WS is reaching out to Colnago for me. I hope there is a solution otherwise I will be looking to have it repaired locally.
:cry:
dfischer1
by dfischer1
Doesn't look that structural, and since you don't ride it that much, just glue it back together and it'll be fine. That's how the rest of the frame is built anyway...
TonyM
by TonyM
Where is the crack? don't see it
Edit: ok now I see it!
Ringo
by Ringo
That doesn’t look good.
From what I’ve heard Colnago’s after sales support isn’t good.
I’m starting to have second thoughts for my purchase of c60..
Calnago
In Memoriam
by Calnago
Yeah, that’s not structural, but it sure is disheartening. There’s a thick layer of paint around the cable guide insert. That insert has come loose and hence the paint has cracked. Unfortunately, to get a cosmetically good repair will likely cost some coin, which doubly sucks because it’s so minor. Or you could just take a really fine toothpick or something and get some kind of adhesive in the crack, clamp it tight then once cured, try to cover the crack with modeling paint as best you can. But without sanding and all that it can just make it look worse. If you press in on the insert, does that close up the crack somewhat?
Bigger Gear
by Bigger Gear
Calnago wrote:
Thu Apr 12, 2018 6:16 pm
Yes, pressing on it does close it and if I keep heavy thumb pressure on it I can keep it from opening when the brake is applied. I will await the response from Wrenchscience but I'm not super hopeful. I too have heard Colnago horror stories. And it is very disheartening, this bike has less than 5000 km on it and has been babied the entire time. If I do have to get it repaired myself I will spend the money to do so properly.
All I can say about Colnago, based on my experiece of owning both an Extreme Power and a C60: they are beautiful to look at, and have good riding geometry but they are not without their little issues. Kind of like Italian sports cars I guess. My EP had issues with the front derailleur hanger alignment and was sent back before I built it. This C60 had a slightly oversized steerer (28.9 for a nominal 28.6). I had problems gettting the slotted bearing compression ring to insert completely into the bearing, so much that the first one broke (the Arcos rings are plastic). I ended up using fine grit sandpaper to sand down the fork to 28.6 mm. Also the crown race did not sit well on the fork due to some paint uneveness, again sanding this slightly to make it right. Later versions went with an integrated carbon race on the fork.
MyM3Coupe
by MyM3Coupe
Sorry for the damage. That sucks. Three year warranty though? Holy crap that’s weak. Specially on a high dollar item like that. I’d skip Colnago. Get it fixed and ditch it on eBay.
TonyM
by TonyM
MyM3Coupe wrote:Sorry for the damage. That sucks. Three year warranty though? Holy crap that’s weak. Specially on a high dollar item like that. I’d skip Colnago. Get it fixed and ditch it on eBay.
That’s a good one!!
I am buying it at 50% discount! Send me ebay link....LOL
It is not structural.
Ok not nice when you pay so much but completely normal if I take my own experience with Italian goods (Colnago, Ducati, Vespa, Ferrari,...).
I would use some glue and touch paint and basta!
Kumppa
by Kumppa
To be honest 4000€+ frame, well known, respected maker and 3 year warrantly is pretty ridiculous. Thats sound like they just want take money and not care about happy customers after years of riding quality and well made bike. That warrantly is just one big no no to me get brand new.
mattr
by mattr
Meh, we used to be dealers (back in the C40 days and before) and the importer wouldn't even accept frames or bikes that were wrong out of the box back. Not without legal threats and quoting various bits of contract law. As they knew they'd have even more problems getting anything back from Italy other than a shrug.
Then the boss switched to Bianchi for our high end road brand.
Amazingly, they were worse.
r4nd0mv4r14bl3
by r4nd0mv4r14bl3
MyM3Coupe wrote:
Thu Apr 12, 2018 8:09 pm
Do you think making purchase decisions based on the length of warranty is reasonable? In some European countries, Korean car manufacturer Hyundai offers 7 year warranty. Compare that to BMW who give 2 or 3 years while being three times more expensive. People are still buying BMWs.
Sorry for off topic, couldn't resist.
TLN
by TLN
r4nd0mv4r14bl3 wrote:
Thu Apr 12, 2018 9:39 pm
AFAIK BMW is doing 6yr 100k warranty for CPO cars.
Means I can get CPO after lease 3series for Elantra money and still have 3-4 years of warranty left.
His: Specialiez S-Works Tarmac SL5 Disc.
MyM3Coupe
by MyM3Coupe
[/quote]
[/quote]
A $60k car is comparing guns to grenades. My point is a $5,000 bike frame should have a long warranty. I have two Time frames (less than $5000 frame) and they have lifetime warranties. As does Trek and other. Colnago clearly realizes their quality/quality control is crap.
AJS914
by AJS914
It's always been like this - about 30 years ago the wealthier guys in my club all went Italy and came back with titanium Colnagos. They all broke one by one just out of warranty which I think was one year back then. They were all SOL. At least these days, carbon is easily repairable. On this one, I would just glue it down since it's just a guide.
So, you roll the dice with imported Italian bikes with short warranties or you buy Trek/Spec with their lifetime warranties.
Heavyhitter
by Heavyhitter
It happened to my C60 also, I was denied warranty cause the paint and finishes are on le covers for 12 months...I ended up with some nail polish and epoxy...that was my third and final Colnago. Now happily on a trouble and stress free Argon 18 Gallium. Riding a 8000 grand (CAD) frame made me nervous every time I had to put it in the car , or riding in bunch.
